PSP image opens in wrong PSP
Safiren
Post by Safiren »
I have trouble opening PSP files in 64 bit instead of 32 bit.
I always work in PSP 32 bit.
When I right-click teh image and select properties it says:, opens with PSP 32 bit. exactky as i want it to be.
When I left click on the image to open it in PSP, it opens in PSP 64 bit
Why is it like that ?
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: PSP image opens in wrong PSP
Post by ehume »
Don't know why this is, but try this:
Choose "Open with . . . " from the context menu.
Select "Choose default program . . ."
Select PSP "2018 (64-bit)" from the list.
If PSP 2018 64b is not on the list, browse for it and select it.
Report back.
Safiren
Post by Safiren »
I want to open the image in 32-bit.
When I left click the image it should open automatically in PSP 32-bit......... but it opens in PSP 64-bit.
I will not have to choose myself every time.
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
ehume
processor: i7 4770k
Post by ehume »
Safiren wrote:I want to open the image in 32-bit.
If you want to have the file open in PSP 32-bit and not have to choose each time, select the 'default" option (it's usually at the bottom of the 2d context menu). Does this work in your system?
Safiren
Post by Safiren »
I don' t have a default option when i rightclick - Open With ...... here is no default option.
I have Search in store and Choose another app
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
When right-click and select "Properties" the properties dialog shows a "Change" button next to the "Opens With" item. When I click on this I can change the program that opens when I open any and all PSPimage files. I am curious can you try changing the program? See if it opens in the new program. Then change it back and see if it fixed the issue? If it doesn't fix the issue, then I think there might be something wrong in your registry. Though I wouldn't know how to fix that if it was the case.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
This what I get :
1. Doing Properties on a .pspimagefile
2. Right click Context menu
3. Double left click on the pspimage file
Safiren
Post by Safiren »
I tried what you suggest. A few times the image opened in PSP 32-bit but next time in PSP 54-bit.
I tried different images but the same happens.
I will try to get an answer in a computer forum.
Thank you for trying to help me.
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
Safiren
Post by Safiren »
hartpaul wrote:This what I get :
I tried this too but it does not change anything. My image still opens in wrong PSP.
I will try to find a solution in a computer forum.
Thank you for you anser.
I have:
PSPX9 ultimate
PSPX5 ultimate
PSP 2018
Windows 10
ehume
processor: i7 4770k
Post by ehume »
The attachment 01Properties.jpg is no longer available
The attachment 02RightClick.jpg is no longer available
The attachment 02Double LeftClick.jpg is no longer available
hartpaul, what version of windows is that from? I'm using Win7-64. I get:
hartpaul
ram: 8 Gb
Post by hartpaul »
Windows 10 Version 1803 as mentioned at end of my Sig.
Wherever possible I try and set up / operate my systems to mirror what the OP has or if I cannot I will say what I used for the test
