File> Preferences> General Program Preferences> Auto Action> Converts Image to RGB 16bits/channel "Always"
This setting does not work. I click on the "Always" button, click OK and it closes - when I double check the setting i find that it had reverted back to "Prompt'.
Is this a bug or why can't I convert photos to 16bit?
Convert image to RGB 16bits/channel not working
CloudyBright
- motherboard: LENOVO 3750 SDK0T76461
- processor: 3_20 gigahertz Intel 12th Gen Core i9_12900K
- ram: 31 Gig
- Video Card: NVIDIA GeForce RTX 3080
- Hard_Drive_Capacity: 512 GB
- Monitor/Display Make & Model: DELL S2722QC
- Corel programs: PSP9 - PSP2023 - Corel Draw
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Convert image to RGB 16bits/channel not working
Which version of PSP are you using?
CloudyBright
- ram: 31 Gig
PSP 2019Kathy_9 wrote:Which version of PSP are you using?
Kathy_9
I've never changed any of the auto action settings but I just tested this is 2019, 2018 and X9 and I can confirm your findings that the changes don't stick.
You can submit a ticket with Corel at the following link.
https://www.corel.com/en/contact-us/index.html
CloudyBright
- ram: 31 Gig
Thank you.
Ticket submitted 10/18/2018
CloudyBright
- ram: 31 Gig
10/20/2018
Corel tech responded that they were able to duplicate this problem and are forwarding it to their Level 2 for further troublehooting.
Kathy_9
Thanks for reporting back.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
If you're interested I have a workaround for you. It requires use of the registry editor.
1) Close PSP
2) open regedit
3) Go to Computer\HKEY_CURRENT_USER\Software\Corel\PaintShop Pro\X11\General\Fixups
4) Find "IncreaseColorsTo16Bit
5) Change the value to 0 for "Always"
PSP should now show "Always" in the preferences dialog.
1) Close PSP
2) open regedit
CloudyBright
- ram: 31 Gig
Corel's tech support response was to select: Image > Increase Color Depth
That works on a one-by-one basis.
And thanks to LeviFiction for a registry edit work-around which I will probably do when I have a little free time on my hands.
