Splitscreen in VS Pro
lazar1804
processor: Intel I7 8700
ram: 8 GB RAM
Hard_Drive_Capacity: 1 TB + 240
Corel programs: Corel Video Studio
Post by lazar1804 »
Hey, guys, I need help with split screen. I don`t know how to use or make split screen templates.
Is there anyone who could help me?
This is printscreen of a VS that I use. You see, I see that split screen is mentioned here but I don`t know how to use it.
Re: Splitscreen in VS Pro
Please refer to this recent post to save us typing the details again.
viewtopic.php?f=1&t=64462#p362044
The Split screen icon is far right of the tool bar adjacent to T3D
lazar1804
ram: 8 GB RAM
Post by lazar1804 »
Thanks a lot! I had been searching for that topic but I didn`t find it. :)
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Would this tutorial be of any interest ?
https://learn.corel.com/tutorials/video ... it-screen/
Ken
lazar1804
ram: 8 GB RAM
Post by lazar1804 »
Well, this video doesn`t explain how to remove numbers.
When I insert videos in template they are still there.
Post by BrianCee »
It doesn't need to explain - because they just vanish when you put your clip in the timeline - as shown in that tutorial
lazar1804
ram: 8 GB RAM
Post by lazar1804 »
Okay. Thank you for your answer.
I still don`t know how to use splitscreen because every time some effects turn on even if I didn`t choose that.
Whenever I put some video in placeholder something strange happens. Every time I see some different effect/transition.
Does anyone know how to turn them off? Whenever I try to remove them (in the same way I remove transitions in other videos) I actually delete the whole video in place holder.
Making split screen videos is very important to me. I mean, that`s the main reason I want to buy this. My trial version expires in two days and I am about making a decision.
Tutorial mentioned above doesn`t show that problems. It isn`t that easy.
When they put a video in place holder there are no effects but in my case they exist.
Thanks a lot!
Ken Veal
ram: 32 GB
Post by Ken Veal »
Perhaps someone will be able to help you if you list in detail your workflow, that is, what exactly you are doing and in what order and what you see.
lazar1804
ram: 8 GB RAM
Post by lazar1804 »
Ok, I will do my best. Maybe I will make the screen recording.
Post by BrianCee »
OK - sounds like you are not matching the length of the videos to the length of the split screens tracks and because of that Videostudio is applying a transition to merge the two tracks
I am assuming you are using the supplied templates and not trying to create a template from scratch
first requirement is that all the videos you want to use are the same length and match the length of the split screen template - SO when you drag down and place (or otherwise insert ) the split screen template you need to set all the black tracks which it inserts to the same length as your videos - do that by double clicking on each one individually - this will open the options panel which if you look has 3 tabs along the top - by default the panel opens on the 'effect' tab - change to the 'edit' tab - in the top left corner there you will see a small digital clock - click on the number you want to change (hours:minutes:seconds:frames ) to set the time using the up/down arrows to the length of you video - repeat for all tracks
now when you drag your videos down from the library as you get anywhere over the black holder in a timeline - WHILE STILL HOLDING THE LEFT MOUSE KEY DOWN press the ctrl key - now release the left key before the ctrl key and when you do release that the new video should now exactly replace the black placeholder without any effects being added
the lowest track added by the template is the split lines onscreen - if you do not want those lines you can just delete the very lowest black place holder
lazar1804
ram: 8 GB RAM
Post by lazar1804 »
https://youtu.be/vtq_orSG4_4
Ok, I realised that I shouldn`t drag videos from "tracks" but from "edit" part of software.
I will try the other way now.
Thanks a lot, man!
You really helped me.
Tomorrow my trial version expires so I need to find out if I should buy it.
You did a great effort to explain me what I should do.
Thanks a lot!
What you are doing is overlapping the two clips, VS then adds the transition, not what you want.
You need to replace the clip.
Move the MVI 9433.Mov to the library
Now drag the library clip over the placeholder on Overlay track
As you drag the clip press the CTRL key – drop the clip then release Ctrl
A tool tip should show to replace clip.
