Cubebase audio into 2018 ultimate emits slight noise
judas_64
processor: Intel I7
Hard_Drive_Capacity: 2 tb
Monitor/Display Make & Model: acer
Corel programs: VideoStudio Ultimate 2018
Post by judas_64 »
I've been using corel video for almost 3 years now and ultimate 2018 for nearly a year. The problem I have is when I get the audio where I want in cubebase and import it into videostudio as a wav, mute my video audio everything is good. Not until I save as mp4 4k 60 that the finished product sounds like squiggly air. I can play the audio in every program with no issue. Only when videostudio converts and compresses. I've tried lowering my audio from 96/24 to 44/16. Same problem. This
Is very noticeable in softer music with pauses such as orchestral pieces. My guess is videostudio has a conversion issue as media player and several others do not have this problem. Any ideas??
Thank you!!
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Cubebase audio into 2018 ultimate emits slight noise
Post by asik1 »
It would be nice if you upload a 30 sec wav segment for us to try and understand that issue.
Panasonic X900m, VXF1
judas_64
processor: Intel I7
Post by judas_64 »
I've been trying, and everytime I attach the files, it dumps me out... I'll keep trying...
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
judas_64 wrote:I've been trying, and everytime I attach the files, it dumps me out... I'll keep trying...
you can't upload here, you need to upload to sharing site.
judas_64
processor: Intel I7
Post by judas_64 »
Okay, I created a DropBox account and placed the samples there---
Thank you!!
https://www.dropbox.com/sh/mbs8dvfp06jb ... DqNBa?dl=0
weaver
processor: intel i7
Video Card: nvidia Ge Force GF 550 Ti
sound_card: C.Media
Hard_Drive_Capacity: 20TB
Monitor/Display Make & Model: FULL HD
Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
Post by weaver »
It is very interesting, I work with VS over decades ( started with Ulead. :-) ) and never had such troubles ( a made lot of concert and theater videos). The only difference to your experience is, that I do not use Cubase. ( my audio editors are Audiocity and Music Maker from Magix).
I use almost all audio formats WAV, MP3 etc with different settings and Zoom recorders. Try to check the Cubase time base settings, it looks like that there is some glitch between the video and audio time base and that causes the noise.
Do you use some audio filters? ( normalisation, level adjustment).
The normalisation does not work well on VS.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
While I do here the hiss in the "before"
The after is disturbing. further tests needed.
How did you export 96K wav when VS can do up to 48K only?
Complete name                            : I:\downloads\audio after VS2018.wav<br />Format                                   : Wave<br />File size                                : 15.0 MiB<br />Duration                                 : 27s 369ms<br />Overall bit rate mode                    : Constant<br />Overall bit rate                         : 4 608 Kbps<br /><br />Audio<br />Format                                   : PCM<br />Format settings, Endianness              : Little<br />Format settings, Sign                    : Signed<br />Codec ID                                 : 1<br />Duration                                 : 27s 369ms<br />Bit rate mode                            : Constant<br />Bit rate                                 : 4 608 Kbps<br />Channel(s)                               : 2 channels<br />Sampling rate                            : 96.0 KHz<br />Bit depth                                : 24 bits<br />Stream size                              : 15.0 MiB (100%)
Format : Wave
Audio
Format : PCM
Codec ID : 1
Bit depth : 24 bits
judas_64
processor: Intel I7
Post by judas_64 »
I apologize if I was incorrect. I imported 96/24 wav file and it compresses in VS. I believe 44.1k and 192kbs. I extracted the audio from video through Cuba's and saved it. I have the default set at 96/24. You are correct on the slight hiss prior to VS. It almost seems that the software is detecting the hiss and amplifying it bringing it out. The strange thing is when it's stacked with the video, it retains the "before" minor hiss. Only when saved is it quite amplified.
Thanks again!!
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
I will recommend visiting
https://www.audiocheck.net/testtones_hi ... naudio.php
I just D/L the 192K sweep file to test in my 19.2 VS .... interesting result.
Here a music files
http://www.itrax.com/Pages/HelpFAQs.php#1
click the buy of the 96/24 ST one.
judas_64
processor: Intel I7
Post by judas_64 »
Wow... Thank you so much! Can't wait to try these out! I was using a zoom f8 with 3 akg c414xlii's in a bonsai Decca tree. I was at the very back of the hall and might have had the db's punched up to get to the sweet spot. That was the issue with the slight hiss. But the final product after VS is atrocious....
Again, thank you so much for your help!!
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Here few test results of the 96/24 music
Original test file
Original test file
EXport to 48K wav with VS
Wav extracted from VS mp4's<br />using XMedia Recode
using XMedia Recode
weaver
processor: intel i7
sound_card: C.Media
Post by weaver »
Try to cut the original sound to 15-18kHz. It looks like that the VS has no antialiasing filter and your sound components over 18 - 20 kHz create antialiasing glitches ( inverted noise spektrum). I do not think that VS support anything above 20 kHz in the audio signal.
judas_64
processor: Intel I7
Post by judas_64 »
Thank you so much for your indepth analysis on this! I'm now taking my raw wav files and going back to cubebase. I will apply low pass filters in the 15+ khz range and drop them by -12 db or more. Or, if possible just delete beyond the 18 khz range. Again asik1 and weaver, many thanks! I've been pulling my hair out for days. I do have a ticket open with Corel, but they are giving me the run around showing me where their audio filters are and to try them. Their filters actually make the audio worse.
weaver
processor: intel i7
sound_card: C.Media
Post by weaver »
There is also a question where do you get those noise components above 15 kHz. Usually most of the audio devices do not record or process signals in this region ( standards mostly limits the audio range to 20 kHz, and nothing above). In earlier days this problem happened on different synthesizers but the natural sound (classic instruments) does not have auch frequency components. The natural noise and other stuff in this frequency range is very low or the microphones and recorders does not capture them. Your example was some classic music recording full of noise up to 30-35 kHz!!!!
Especially the digital devices are very sensitive for any signals close to the half of the sampling frequency. Therefore in most of the devices there are very precise low passes (high grade filters) which remove all components close and above the 1/2 of the preset sampling frequency. (22,05kHz; 24,00 kHz etc, practically the cut off frequencies are a few kHz lower).
VS is not an audio processing device, that is why Corel will not deal with audio content frequency range. It should be simple compliant with audio standards.
Probably this noise is comming from Cubase - what should not.
judas_64
processor: Intel I7
Post by judas_64 »
Hello Weaver-
That is a very interesting question! I'm looking at Cubebase and it appears that the software only works in the range of 20Hz to 20Khz. My AKG C414 XLii microphones run in the same range.( I was using 3 in a small Decca tree configuration and recording on a zoom F8) I've been using this configuration for some time with no issues, but I will definitely check my setting on my recorder. I was recording a high school symphony / orchestra at a performing arts center. I was all the way in the back and under the control room. I want to almost hedge that it could be some RF interference? Like the sound bytes show its okay(audibly) prior to VS2018 and after Cubebase, with the usual audience noise and a bit of a soft hiss from me punching up the db's, but not too bad. The after VS2018 is quite horrible. If I play in windows media, audacity or other players its okay... I think you're correct that VS2018 is detecting above 18Khz and over compensating. Tomorrow I'm going to painstakingly set up everything exactly how I had it and run some tests.... If all is okay, then I'm going to go back to thinking some interference is the culprit...
