Perfectly Clear - Access Violation
ellington
motherboard: ASUS PRIME A320M-K Micro-ATX
processor: AMD Ryzen 5 2600X Six Core CPU
ram: 16GB Corsa
Video Card: 1GB NVIDIA GEFORCE 710
sound_card: On motherboard
Hard_Drive_Capacity: 2TB SEAGAT
Monitor/Display Make & Model: Dell ST2320L
Corel programs: PSP X6 X7 X9 2019 2020 VS 2019 2020
Post by ellington »
Hi Been using PaintShop Pro 2019 for a couple of weeks now from a download. Everything works fine except for Athentech Perfectly Clear 3.5. which does work but only allows between 3 and 6 photos to be adjusted before giving the "Plugin caused access violation" At this point I need to close down PSP and reopen and get another 3 or 4 photos done before it happens again. I have tried removing Perfectly clear and reinstalling to no effect. Also removed PSP and reinstalled the whole set, again without any difference to the end result. Any suggestions would be greatly appreciated.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Perfectly Clear - Access Violation
Post by hartpaul »
Just tried that with about 5- 6 images loaded, in PSP 2019 64 bit version and can confirm the same result after about 5 successful operations. Seems this is not properly attuned to PSP.
Kathy_9
Post by Kathy_9 »
I typically don't use the 64-bit version of 2019 but I just tested it out and find that after running about 4 images through Perfectly Clear that PSP 2019 crashes. I get the following:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Corel PaintShop Pro.exe
Application Version: 21.0.0.1
Application Timestamp: 5b46a061
Fault Module Name: PASMUTILITY.dll
Fault Module Version: 13.0.0.335
Fault Module Timestamp: 5b1c0050
Exception Code: c0000005
Exception Offset: 0000000000006dc5
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 17db
Additional Information 2: 17dbc9a1a72694165c6523aea280962c
Additional Information 3: b90e
Additional Information 4: b90e144ca950349ff21222d0175b4afe
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
Based on the excellent verification posted above I just opened nine .jpg files in PSP 2018 and applied Perfectly Clear SE v3 to each. I did not experience any crashes. So the problem is either in PSP 2019 or Perfectly Clear v3.5.
hartpaul
ram: 8 Gb
Post by hartpaul »
I can verify ehume's results. The two changes 1. to PSP 2019 and 2. Perfectly Clear 3.5 cause problems.
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
I tested using PSP 2019 64 bit and the full Plugin version of Perfectly Clear 3.5.8.1239 and had no problems. I edited 12 open images one after the other in Perfectly Clear, and I had no crash. I'm running the latest Win 10 1809 version.
ehume
processor: i7 4770k
Post by ehume »
patara wrote:I tested using PSP 2019 64 bit and the full Plugin version of Perfectly Clear 3.5.8.1239 and had no problems. I edited 12 open images one after the other in Perfectly Clear, and I had no crash. I'm running the latest Win 10 1809 version.
Makes me wonder if the PSP 2019 version of PC that fails is 3.5 SE or 3.5 full version. Q for patara - which version of PC 3.5 are you running?
hartpaul
ram: 8 Gb
Post by hartpaul »
My version of PC was 3.5.7.0 so the poster with no problems has an upgraded version.
ehume
processor: i7 4770k
Post by ehume »
All of this makes me glad I decided to stick with PSP 2018, with Perfectly Clear 1,2 from earlier builds and 3 from PSP 2018.
patara
ram: 32 GB
Post by patara »
I'm using the full retail Plugin version of Perfectly Clear. Because I own that I never installed the SE that comes with Corel PSP Ultimate.
My version is 3.5.8.1239 and is the latest available
ellington
ram: 16GB Corsa
Post by ellington »
The Version i bought, downloaded and installed is PSP 2019 21.0.0.119 x64 and PC 3.5.7.0 I have tried it now on two PC's with the same result. Never more than 5 or six photo's before the access violation. My previous version of PSP was X9 with Perfectly Clear 2.0.1 SE. That works fine but was looking forward to the new version in PSP 2019 with the added features. I have tried re-downloading with the link I have which has made no difference. I think the link has now expired as i had no photos to work on originally and never thought it would give problems as all the other versions have worked well from the start. Any suggestions would be welcome.
ehume
processor: i7 4770k
Post by ehume »
ellington wrote:The Version i bought, downloaded and installed is PSP 2019 21.0.0.119 x64 and PC 3.5.7.0 I have tried it now on two PC's with the same result. Never more than 5 or six photo's before the access violation. My previous version of PSP was X9 with Perfectly Clear 2.0.1 SE. That works fine but was looking forward to the new version in PSP 2019 with the added features. I have tried re-downloading with the link I have which has made no difference. I think the link has now expired as i had no photos to work on originally and never thought it would give problems as all the other versions have worked well from the start. Any suggestions would be welcome.
You can COPY PCv2 from C:\Program Files\Corel\Corel PaintShop Pro X9 (64-bit)\Plugins\PerfectlyClearForPSP [folder] to C:\Program Files\Corel\Corel PaintShop Pro 2019 (64-bit)\Plugins\PerfectlyClearForPSP. Luckily PSP 2018 comes with PCv3, so I copied PCv1 from PSPx7 and PCv2 from PSPx9. Now I have all three plugins when I select 'Athentech' under 'Plugins.'
ellington
ram: 16GB Corsa
Post by ellington »
Thanks for the reply ehume but unfortunately by doing that I just end up with version 2.0.1.SE which I can still use in X9. One of the reasons for upgrading was for version 3.5. Having used it the difference in the features makes it so much more attractive having used it, all be it for a small number of times before having to re start the program I would like to continue. Also in my PC which is older it works faster than the version in P
ellington
ram: 16GB Corsa
Post by ellington »
Having had 4 or 5 suggestions from Corel Support, all without a result other than 3 photos through Perfectly Clear before the access violation box comes up to stop you without re starting PSP, I just wondered if anyone who has experienced the problem has any further ideas. Or anyone new who could shed some light on this.
thanks
hdrabkin
Corel programs: Paintshop Pro x9, Aftershot Pr
Post by hdrabkin »
I haven't been able to get PClear to work either in 2018 or 2019 versions. Immediately get 'access violation'. This is even with the PCP included in the 2019 ultimate package.
WIn 10 Pro, PSP 2019, 64bit both;
