crashed at 99%, file .a + file .v
PsychatoR
Post by PsychatoR »
hi, i just tried to export something like 1h Video projet, it result with a crash at 99%.
im stuck with a very tiny .mp4 file, a 869 Mo .a file, and a 8.27 Go .v file....
it there something i can do manually with that? ty
maybe its a too long project and need to be split in 2.
canuck
operating_system: Windows 8.1
Re: crashed at 99%, file .a + file .v
Post by canuck »
Perhaps if you were to describe exactly what you are doing, someone might be able to understand your problem. What sources, what source properties, what output properties, to what are you exporting?
There is very little useful information in your post.
I have no idea what you are describing in this statement: "very tiny .mp4 file, a 869 Mo .a file, and a 8.27 Go .v file..."
PsychatoR
Post by PsychatoR »
whatever output.
it crashed at 99%.
the files is those. what should i do with those? ty
is there a way i could make a video with them?
https://cl.ly/dda2030f4d44
The 869 MB file is pretty obviously meant to be some sort of audio file (.a for audio); and the 8.27 GB file some sort of video file (.v for video). But can you confirm that that is all that appears as the extensions on those two files (i.e. .a and .v). But what were you originally trying to produce from them -- and mp4 video or something else? And have you tried playing either of those files in a player like the freeware VLC Player which will play almost anything? Or have you tried changing the extensions to something else (e.g. change .a to .aac and .v to .mov) to see whether the renamed files will play.
As for the very small mp4 file, how big exactly is it, and does it play video?
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
PsychatoR wrote:it result with a crash at 99%. im stuck with a very tiny .mp4 file, a 869 Mo .a file, and a 8.27 Go .v file....
I've experienced this numerous times when trying to render MP4 videos using VS2018. Are you using VS2018?
Did VS crash silently or was there an error message? I've frequently experienced VS2018 crashing w/o any error message. In any event, I've not found a way to combine the orphaned *.a and *.v files into an MP4 file and I think that even if you could, there'd be something missing.
The best way that I've found to avoid the crashing is to render using VS10 as rendering MP4 with VS2018 is too hit and miss.
tletter
The A and V files are temporary files created during rendering to mpeg4, on completion they are removed / deleted leaving the new rendered Mp4 file.
The name “test a v files_1009_13-10-43.v” indicates the name and date of the render.
1009 being October 9th + the time.
Failure of the render does appear to leave those files behind.
So those files are normal the problem being the crash at 99%
The screen shot being taken part way through a render.
click image for larger view
tletter
Post by tletter »
lata wrote:So those files are normal the problem being the crash at 99%
Not sure what is being said but orphaned *.a and *.v files are left behind whenever VS2018 crashes at any stage of rendering a MP4 file. Unfortunately VS2018 crashes too frequently.
tletter
