"the print setup dialog failed to initialize" This started popping up whenever I try to print a picture from psp 7 ver 17.4.0.11 64b, Ive tried it on 2 different printers, and all my drivers are up to date
Does any one know how to fix this?
Edit, I've just upgraded to psp 2019 ultimate, getting the same error
John
Error message when trying to print
Re: Error message when trying to print
Does the same thing happen when using the 32 bit version of PSP?
jmf1964
- motherboard: gigabyte z97
- processor: i7 4770
- ram: 32gb
- Hard_Drive_Capacity: 5.5tb
- Monitor/Display Make & Model: samsung
- Corel programs: paintshop pro x7
Ken Berry wrote:Does the same thing happen when using the 32 bit version of PSP?
Yes, 32b as well
The printer will print from other paint programs, but not paintshop.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
Does not sound like PSP7, which is v7.04, a JASC product. Sounds like PSPx7, a Corel product.jmf1964 wrote:"the print setup dialog failed to initialize" This started popping up whenever I try to print a picture from psp 7 ver 17.4.0.11 64b, . . .
jmf1964
- ram: 32gb
yes it is corel psp x7ehume wrote:Does not sound like PSP7, which is v7.04, a JASC product. Sounds like PSPx7, a Corel product.jmf1964 wrote:"the print setup dialog failed to initialize" This started popping up whenever I try to print a picture from psp 7 ver 17.4.0.11 64b, . . .
also does this in psp 2019
Also just discovered it will print if I choose the center on page but then it prints a small pic in the center of the page, it will not print if I choose the "fit to page" option.
and now when I try to resize the image the program crashes, no error message it just shuts down.
Edit,
I just installed psp x7 in my hp laptop, does the same thing there.
- hartpaul
- ram: 8 Gb
You have not mentioned which printer and model number. That would help so that others who have the same printer(s) can test to see if they have the problem.
Have you used the same printer cable from your computer - tried a different cable?
also list the steps you are using to print.
I have only used the print function in any version of PSP to test out problems that others may be having with their printer.
If it is worth printing, it is worth saving. A saved image can be printed in / from other programs - I prefer printing test images from Irfanview a free program.
If I want to print a higher quality image I will use a professional lab.
jmf1964
- ram: 32gb
hp laserjets
m251 and m277, same error regardless, both will print from other programs without issue.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Unfortunately the vast majority - if not almost all - of printing problems reported in this forum have been with HP printers. I don't recall that any solution has been found, but others might recall if any fixes have helped.
JoeB
Using PSP 2019 64bit
JoeB
jmf1964
- ram: 32gb
Turns out the jpeg files were corrupt some how I replaced them, problem solved.
