Hi Guys,
Sorry if this has been asked before.
I need what I think is a basic script that I can use in batch processing that will open and image and make the smallest side the same as the longest side and then resize the entire image to 1000x1000 pixels unless it is less than 1000 pixels x 1000pixels already.
If someone could point me in the right direction I’d really appreciate it.
Many Thanks
Tom
Image Resizing
tommyallitt
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Image Resizing
No, this particular thing has not been asked before, I don't believe. Most people are against distorting their images. I have been asked to make a script that adds a border to the short side to make it equal to the long side, no resizing necessary. It just ends up with a black box around it.
I think you could do this easily by recording a simple resize action into a script. Don't worry about the values, just record a script that uses resize and save it out. Open the script in an editor like notepad. Then adding a single line of code just before the Resize command, and finally replacing the appropriate parameters in the resize command with the variable we create.
Python has this neat function called "max" which takes two numbers and returns whichever number is greater. It also has the opposite called 'min' which returns the smaller of the two numbers. What we do is we pass in the width and height to max() and it tells us what the longest side is. Then we pass this into min() with the number 1000 and whichever is smaller becomes the new resize parameter we'll use. The code looks like this
Then replace the Width and Height values in the Resize command with SideLength
The end result is the image is distorted to make the width and height match, and if they are larger than 1000px they are resized down to 1000px. If they are smaller than 1000px then nothing else is done.
Code: Select all
SideLength = min( max( App.TargetDocument.Width, App.TargetDocument.Height ), 1000 )
#resize command begins here
Code: Select all
#This is pseudo code and cannot be run by PSP
App.Do( Environment, 'Resize', {
#....other parameters,
'Height': SideLength,
'Width': SideLength,
tommyallitt
Re: Image Resizing
Hi Levi,
Thank you so much. That was a huge help. Just what I needed. I tweaked it slightly to give what I needed as I didn’t want to distort the images so I used the max function to set the canvas size and then used the min function to resize the image to 1000 unless it was already smaller than that.
This will save me a huge amount of time when preparing product images for our website.
Thanks again.
Tom
Thanks again.
Tom
