Multi-Camera and Shooting Date/Time
ispyisail
Post by ispyisail »
Hi all
There appears to be very little information in the manual about "Shooting Date/Time" in respect to aligning video clip in the Multi-Camera?
What video formats support "Shooting Date/Time" time code aliment?
I have 3 video cameras (Canon MF105) all genlocked but it appears that video studio doesn't support Shooting Date/Time with MXF file formats?
ispyisail
Re: Multi-Camera and Shooting Date/Time
Post by ispyisail »
Doing some research
My best guess is that "Shooting Date/Time" is supported with DV cameras?
DV cameras support either raw DV stream, AVI, WMV or QuickTime
Do all these formats/containers support "Shooting Date/Time"?
Not really noticed that option but would think it of little use.
The idea of MCE is to sync video recordings that were taken recording the same scenes.
I don’t see how Shooting date and Time can do that unless all cameras have their time set to one frame accuracy?
Maybe I have the wrong idea of that function.
The audio option would be my first choice, then markers where a clapper board or flash has been used to mark the recordings.
Where cameras have been locked together recordings would start at the same time, so syncing the clips would not be required, they would already be in sync.
Are you having any problems in using your 3 cameras recordings?
ispyisail
Post by ispyisail »
"Where cameras have been locked together recordings would start at the same time, so syncing the clips would not be required, they would already be in sync."
No
My cameras are gen-locked but the record button for each camera has to be manually pressed. They all have different start times but the time clocks are exactly the same.
https://en.wikipedia.org/wiki/Genlock
I've used one of the other methods to sync the video.
I've gone to all the trouble to sync the cameras so I want to use a feature that exists.
I'm fast coming to the conclusion that nobody ever uses the "Shooting Date/Time" feature?
Its highly possible that that this feature does not even work?
ispyisail
Post by ispyisail »
This is the reply from Corel
I have checked regarding this with the next level team and found that if the file has time code stream then there is no way open it in the Videostudio.
After some time I suspected this might be the case
My guess is when you are importing DV footage you can manually set a time code.
Seams like a pointless feature?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
"Shooting Date/Time — Click the Sync button to synchronize the clips according
the shooting date and time as indicated by the metadata recorded by the camera.
Note: The clocks must be in sync on the cameras to get accurate results"
- From PS22 pdf.
I just did a short test with that, using my MTS files, and it's working
As you can see I loaded 3 files I shoot at event, (single camera) once I selected 'Shooting Date/Time' they been placed on the timeline relatively to their Date/Time time.
As VS is not for "professionals" using 2000$ and up camcorders it do not read LTC.
Panasonic X900m, VXF1
weaver
processor: intel i7
Video Card: nvidia Ge Force GF 550 Ti
sound_card: C.Media
Hard_Drive_Capacity: 20TB
Monitor/Display Make & Model: FULL HD
Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
Post by weaver »
Genlock and timelock is not the same issue. Genlock synchronizes just the videosignal time base but not the time recorded on the cameras. Genlock is important for a multicamera live editing in studios, live transmission etc, but not aonymore for offline editing like VS. All off-line editors synchronize the video (genlock) automatically.
In digital world, the importance of genlock is marginary as almost all devices in video chain have its own time base corrector (TBC) what takes care about the video synchronisation. This of course introduce some delays in signal processing, but this is a secondary issue. That is why today you can mix video signals almost in any format (25i,29,97i,50p et,)
A time synchronisation (timelock) is usually an independent timecode generator, its signal is recorded simultaneuosly in each device (cameras and recorders, and you are right, DV was probably the last format having embedded time recording track).
The new recordings on different memory cards usually do not have the time synchronisation feature, as the saving/processing time is off-line and each device has its internal time information ( time setting on the camera) but this clock does not have an external genlock or synchronisation input. (We are talking about commercial devices). The time recording on one of the audio channels would be an option, however most of the modern cameras use audio compression, what may introduce audio delay and other problems for a real timecode based synchronisation.
The idea of sorting the recordings on time line is nice, but I do not think that it is very practical, because if your cameras are individually started you will get lot of rubbish there. In such events I always record everything in whole length on all cameras ( my biggest project was 6). At the beginning I try to get some sync scene like the clapboard and place all recordings on the time line, search for the clapboard and shift all recording to the same time. Very useful is the audio view fir this job.This synchronizes all recordings and I can cut among the camera signals.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Weaver, the 'genlock' port used there as input for slaved LTC, and must be set as Free Run.
MXF container can have LTC, VITCas well as userbit like the good old days...
https://tech.ebu.ch/docs/r/r122.pdf
ispyisail
Post by ispyisail »
Yes I am aware of this, I was using Genlock as a loose term.
My mixer has the Genlock signal and the timelock is set on the cameras before start.
For this project I didn't take my mixer so only timelock on free run.
Disappointing that VideoStudio can't pick up MXF time code :(
ispyisail
Post by ispyisail »
using my MTS files
What are MTF files?
Videostudio does try to sort MXF files, They are close but not useful as they are out
ispyisail
Post by ispyisail »
How to you know if they are exactly in the right place?
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
mts's are the video files that our "common people's" camcorders make :lol:
** The earliest file is set at 0 on the time line, than the other at the correct interval and so on.
Next time when you shoot the same try to set your clocks together (best as midnight 000000) and you will be just within 1 sec sync error at most.
***Can you upload for us 15 sec MXF (can be just 9MB/s) file with timecode? say start it at 11:11:11:00 so we can try it in other NLE's?
ispyisail wrote:How to you know if they are exactly in the right place?
Not having multi cameras to test the MCE I used video samples.
The original samples were from 4 cameras linked together so when hitting record all cameras started at the same time, audio sync being achieved I do not know what equipment was used to do that?
All 4 recordings having the same audio so syncing within MCE was not necessary.
For this test I have rendered sections from the original videos to create out of sync clips
Effectively recording starting at different times.
Using MCE scans the clips and positions them in sync, in this example syncing to Camera 1.
We can view the wave form to identify / see the sync results, to me looks pretty accurate.
click image for larger view
weaver
processor: intel i7
sound_card: C.Media
Post by weaver »
asik1 wrote:Weaver, the 'genlock' port used there as input for slaved LTC, and must be set as Free Run.
That is correct but you need the LTC time code generator and some distribution network for that and a genlock port input on cameras.
