Diffraction Filter position
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Is it possible to reposition the centre of the "star" to show as on top of a building in VS 2018 ult.If so, how.
Ken
Ken
weaver
- processor: intel i7
- Video Card: nvidia Ge Force GF 550 Ti
- sound_card: C.Media
- Hard_Drive_Capacity: 20TB
- Monitor/Display Make & Model: FULL HD
- Corel programs: VS S6,8,10 on W XP, VS X4,6,7,2018
Re: Diffraction Filter position
I do not have the 2018 version, but on the earlier versions there is a filter setting/property. If you open it you will see the position at least on two points - beginning and end. You can adjust the positions and you can also add keypoints anywhere and adjust the position off the effect.
On the bottom part you can mostly adjust also the style of the effect.
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Place a white color board in Overlay1, then drag the Diffraction filter onto the color board, resize and position the overlay to the correct location on top of your building, then set the transparency to 99, now you should have the star in the correct location
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
Place a dummy 16x9 or 4x3 dummy png on overlay track. Add star to it and place wherever.
Ken Veal
- ram: 32 GB
RobertOZ,
thank you for your advice. I found that setting the transparency before repositioning and resizing allowed for easier and more precise adjustment.
Pepegota,
Think I need more details on your method, I am doing something wrong somewhere. By “dummy” I guess you mean just a transparent place holder or carrier. How do I get it to be 16x9 and does it need to be as the overlay can be resized anyway .To get a png, I saved a white back ground as a png then imported it into the library, but after adding the fx the overlay keeps its white background
Ken
Pepegota,
Ken
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Ken, if you save white than it will be white.
Save transparent image.
Or in other words save an image with nothing.
Panasonic X900m, VXF1
Ken Veal
- ram: 32 GB
Never having saved an image with nothing before and not really knowing how to do that, I returned to Paint Shop Pro 2019 and saved a white image made transparent via the .png optimizer.I imported this into VS and got VS to recognise it as transparent by selecting overlay options via Mask and Chroma key.I then had a transparent overlay that I could add the Diffraction Filter to.I do not see any advantage over this method as against just making an overlay transparent via increasing the transparency field to 99.But it could be of course it could bethat I am not following the correct workflow.
asik1
- ram: 8gb
Ken, I don't have/know PSP but I'm sure you can set it to make transparent background canvas as you set new image. Once you do so save it as PNG.
Hi Kenneth
Open PSP
File New – set size to 1280 x 720, that is 16:9 ratio.
Choose / tick transparent below the Colour box
OK to open image, shows as grey and white squares
File - Save as
Save as type select PNG
Give it a name, save image.
Import to Video Studio Overlay track will show as fully transparent
If you use in top track it will show as black. Use Overlay track
Add your FX effect
Open PSP
File - Save as
Add your FX effect
weaver
Here is the method how I do such things.
Put a white background from the bachground library. This is for optional overlay with transparency)
Select the start from the effect library
Edit the position of the start (yellow mark).
In the effect editor you can add tabs and adjust the location as you like, the star will follow the adjustment.
The black line in the editor is showing the programmed motion of the star. ( the line is not visible, just one + will show the location of the star in each tab on the time axis.
On the last real picture for eg. the star follows on the video the the walls of the fort.
asik1
- ram: 8gb
Weaver, can you attach the VSP for that. looks as I do no have same FX on my X9.weaver wrote: Here is the method how I do such things.
** OH... got it , you used star fx. Ken was referring to diffraction
weaver
yes I used a start filter, is easier to demonstrate and it has a function to relocate. The diffraction fiter does not have this. For that you have to use the method mentioned by Trevor. Put the diffraction filter on the white or black background and overlay this on your picture.
Test 2 shows the star.
Test 3 is the diffraction
In Test 3 there are 2 options. On the first overlay you can place the static picture and adjust its position from frame to frame,.
Onn the overlay2 there is a motion follower, the star remains on corner of the bastion when the camera moves or zoomes.
The system does not allow me to upload the vsp files.
Eugen
Ps. Send me in PM you private email, I will send the the vsp-s
Eugen
asik1
- ram: 8gb
No need Eugen, once I noticed your star fx all was clear to me.
weaver
here are the printscreens.On the top you see on the right side just the black screen with the start on it. In the reality it is a very small black picture (400x300 pixel). You can adjust the size.
The star on it will follow the scene from the camera (motion control) ie it will stay always on the corner of the bastion (see the bottom screen.)
The green star has a programmed motion and will sweep on the top of the wall. (Phases)
