The whole concept behind the "enhancement" of the crop tool since the 2018 implementation is bizarre! Which doesn't say much about the person(s) responsible for it either, I'm afraid.flagpole wrote:It seems a bizarre time to apply the enhancement.
Update for PSP 2019 is here
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Update for PSP 2019 is here
JoeB
Using PSP 2019 64bit
JoeB
theavy
- motherboard: Dell 0CNDTP A00
- processor: Intel Core i7-9750H
- Video Card: NVIDIA GeForce RTX 2060 6GB
- sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
- Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
Has anybody had any luck installing this update? I get an error message saying that the location for "PSPPro.msi" is incorrect, and it's nowhere to be found in any of the installation folders that are created while the update installer is running.
Thanks1
Tom
Thanks1
Tom
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Find the PSP2019_ult.zip file from the original installation. In the setup folder are the .msi files. The installation process stops a number of times (I'm in the process of installing now so I don't know how many of the files are needed) with the message that the .msi file is not available. You need to move them to the folder in which the zip file is located because the Browse dialog sees only msi files and that can't be changed (another dumb setup). So when installation stops looking for one of these files use the Browse box to locate what it wants. Tedious.theavy wrote:Has anybody had any luck installing this update? I get an error message saying that the location for "PSPPro.msi" is incorrect, and it's nowhere to be found in any of the installation folders that are created while the update installer is running.
Thanks1
Tom
Mark
theavy
Thanks MarkZ... that got me going! I agree with you - what a dumb setup, and what a pain!
Tom
Tom
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
There's nothing in the release notes that I'm overly excited about. So I am just going to refuse to install until they fix the patch. It's been reported so hopefully they do it soon.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
For me, this release is valuable :LeviFiction wrote:There's nothing in the release notes that I'm overly excited about. So I am just going to refuse to install until they fix the patch. It's been reported so hopefully they do it soon.
There is a big fix :
Text presets: Resolved unconstrained gradient issue
In previous version :
Create a text with gradient.
Move it with the Pick tool
Gradient will change inside the text.
With the new fix, gradient will stay as is was created.
The list of open files under Window menu was also a missing feature. When working with multiple files open at the same time on the workspace in untabbed mode, it was impossible to select the needed file without many manipulations. Now the workflow will be faster.
In Google maps, adding a location was sometimes impossible. It was very irritating and time consuming. Now, it is corrected and it is a good news.
JoeB
- ram: 8 GB
I'm with @LeviFiction on this one. Nothing in the release notes does anything for me, so I'm not going to bother going through the hassle of trying to install the patch. So now Corel needs a patch to fix the patch - again, unfortunately because, if I recall correctly, they had to do the same thing with a patch to X8 or one of those previous versions.
JoeB
JoeB
For those wanting to install the patch without waiting for Corel to fix its installation method, details of what is necessary are contained here: viewtopic.php?p=362335#p362335 It's tedious, but it works.
Nature_Passion
- motherboard: A75MA-P35 MS-7697 PO
- processor: AMD A8-3870
- Video Card: 193P+ 512MB ATI AMD Radeon HD 655
- Hard_Drive_Capacity: 1863 GB
- Monitor/Display Make & Model: AOC 183P+
- Corel programs: PSP Pro 2019 Ultimate, After Shot 3,
Many Thanks Guys! Your installation Instructions for the Update worked..I lost count of how many times i had to repeat but it was so thrilling to be able to watch that percentage keep moving up after fighting it most of the day...I copied the zip files into Temp and worked from there...it was easy once you pointed out the location... just time consuming...Version is now Corel PSP 21.1.0.22 x64...
Nena
- motherboard: Dell Inc 0HHV7N
- processor: Intel Xeon W-2223
- ram: 32 GB
- Video Card: NVIDIA T600
- Hard_Drive_Capacity: SSD 950GB
- Monitor/Display Make & Model: DELL U2722D
- Corel programs: Paint Shop Pro 2019
Thanks for the informations, but I don't have the file PSP2019_ult.zip, when downloaded came the .exe file and don't know where this .exe is, can't found in my PC. Mystery... Any help, please? Hugs, Nena
- flagpole
- motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
- processor: Ryzen 2600
- Video Card: RTX 2060
- sound_card: on board
- Hard_Drive_Capacity: 6.5TB
- Monitor/Display Make & Model: Iiyama 27"
Anyone know of the update has been integrated in to the main installer yet?
I thought this might be an alternative installation method???
As advised in another thread, I advised that I had raised the issue with Corel. They have now replied: see viewtopic.php?p=362410#p362410
To summarise, they are taking the update patch off their website while they are working on a solution. They say that the problem does not arise where the original PSP 2019 installation was done from a purchased disc. In other words, it only appears where the original installation of PSP was done via download -- which I would think probably covers nearly all of us these days!
Jean-Luc
Is the "new" update officially released for those who own the first 2019 version ?
Zantara
- processor: i5-2100 3 10 Ghz
- ram: 12Gb DDR4
- Video Card: Intel UHD graphics 620
- Hard_Drive_Capacity: 256SSD 1TB
- Corel programs: From PSPX2 to PSP2022
It is, Jean-Luc: https://www.paintshoppro.com/en/support ... dirlang=en
I am going to download it now and hope for the best.
- flagpole
It's funny they left the release dates the same. It's as if the whole debacle never happened.
