Roto Pen Issue
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Roto Pen Issue
Post by Ken Veal »
I am attempting to make a new path with the Roto Pen FX in VS2018 Ult .I made the 1st path with a car symbol with no problem. The 2nd path is with the “walking” man.
The car path goes around a sharp right hand bend but then shows as if it is reversing, can I change this at the point of it appearing to reverse ?
Do I understand correctly that there is no way to alter the direction of the man as there is with the car.
When I cllick on Style under the Path tab and choose a new path color or design, it only shows as a solid line after applying it.
The animated man only shows for a fraction of the 2nd path.
Help please
Scubbie
motherboard: Asus N76VJ
processor: Intel i7
Video Card: NVidia GeForce GT 635M
sound_card: Realtek HD Audio [built in]
Hard_Drive_Capacity: 3TB +Ext.
Monitor/Display Make & Model: Asus & Hanns G HX281
Corel programs: VideoStudio Ult., PaintShop Pro Ult.
Re: Roto Pen Issue
Post by Scubbie »
I'm not sure about what has happened with the walking man for the second path, but having tried it, I can only get all the animated symbols to face one direction. This is to the left.
I guess that it isn't that intelligent.
You could load your own symbol and use an image of the front of a car. This way it wouldn't matter too much which direction that it was meant to travel.
Ken Veal
ram: 32 GB
Re: Roto Pen Issue
Post by Ken Veal »
Not at my pc at the moment.I have downloaded 2 car images same colour and make, both face different directions.I thought I might be able to change images at the point where the direction change takes place.Also thought about using the walking man in a completely new edition of Roto Pen but with the same map so that it follows on from the car route as originally intended and he keeps moving along the entire route.
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Roto Pen Issue
Post by RobertOZ »
Hi Ken,
Have you tried Route Generator, it is a bit more intuitive than Roto Pen and it's free
http://www.routegenerator.net/
