Using curves for non-linear motion/ pan&zoom
Dirk184
motherboard: Intel
processor: i7-7700HQ
Video Card: NVIDIA 1050
Hard_Drive_Capacity: 512 GB SSD
Corel programs: VS 2018, PSP 2021<-> x3, MotionS
Post by Dirk184 »
Is it possible to create non-linear paths or zoom in effects in VS2018 - preferably with curves.
For Example: Zoom-In starts fast and ends slow and smooth - without inserting "manual" keyframes?
Maybe a function in VS2019?
Dirk184
motherboard: Intel
Re: Using curves for non-linear motion/ pan&zoom
Post by Dirk184 »
The Pan&Zoom Function has an "Ease In" Option but no "Ease Out" Option.
I like to have more Options.
Maybe an Admin should move this question to the wishlist for 2019.
Post by BrianCee »
If you put a path on the clip - from the path library - then open 'Customise motion' you can modify the path if you wish and save it as a custom path for future projects - then your image will follow the path - as for zooming - two extra key frames and apply the necessary opacity at each and the job is done - no big deal
Dirk184
motherboard: Intel
Post by Dirk184 »
Thanks for your reply, Brian.
Using (customize) path for Motion is clear but how could I use a path for zooming - can you give more details or upload an example?
Post by BrianCee »
if you open the 'Customise Motion' panel you will see that as well as motion and path you can set 'opacity' (transparent to full opaque) as well as size (zoom to any size ) while following the motion path - see image below
Also made a short video - made in less than 5 minutes - showing fading - zoom is just as easy - watch here - https://youtu.be/AiuS5EXjwTY
Do not be afraid to experiment -- if you get in a mess delete and start again - your original clips are not in Videostudio
click on the image to see it bigger
Dirk184
motherboard: Intel
Post by Dirk184 »
Brian - Thanks for this tutorial - helps me a lot. :D
Meanwhile I found another way to change the linear speed during zooming by using the NewBlue FX VII (Auto-PAN).
NewBlue FX
NewBlue FX
