cut a series of commercials out
diablo
Post by diablo »
how do i cut a series of commercials out of a vhs tape i just captured?
what procedure do i use
thanks
TubaDad
Post by TubaDad »
transfer it into UVS and you will be able to do multiple cuts easily.
Bruce Bennett
VideoStudio 11+ (started with VS5)
PhotoImpact 12 (started with PI11)
THoff
Post by THoff »
If you have UVS 7, use "Extract Video". In UVS 8 & 9, it's called "Multi Trim".
This feature allows you to define multiple regions down to the frame level of the source video and decide whether to keep or delete those regions.
diablo
cutting
Post by diablo »
in multi-trim
on the parts i want to save just hit start and then the end button and just play over the commercials.
for example, at the beginning of the video hit start then go til the first commercial starts and before the commercial begins hit the end buttom (arrow), then just play the commercial till the commercials over and when the show starts up again after the commercial hit start button again etc,
is this the right way?
THoff
Post by THoff »
The procedure is explained in detail starting on page 72 of the manual. If you want an electronic version of it, you can download it here.
diablo
thanks
Post by diablo »
THANKS!
