Make uneven panning speed appear appear smoother?
TT814
- Corel programs: VideoStudio 2018 Ultimate
I have VideoStudio Pro 2019 Ultimate. I'm relatively new to video editing but have looked at all the tutorials. While recording, I apparently was not very good at keeping the camera moving at a constant speed. Parts of the pan move quicker than others. Is there a way to make it look smoother (same panning speed throughout?)
Thanks.
TT814
Thanks.
TT814
Re: Make uneven panning speed appear appear smoother?
Welcome to the forum!
To start with, though, I assume your reference to VS 2019 was a typo, and you meant VS 2018 which is the latest version.
I'm afraid that I don't know of a way to achieve what you want with existing video. Others may have other ideas, and I too will look forward to hearing them if they are presented here.
Like you, I also worry about the speed of pans, and used to try to keep them both slow and as steady as possible when holding the camera in my hands. However, as definition continued to increase and the slightest hand shake or change of panning speed became more obvious, about 10 years ago I finally invested in a decent tripod with a fluid head, and that made all the difference. Velbon still have these at a price well under US$100.
TT814
Thanks, Ken, for your reply. I thought that was probably the case. And 2019 was a typo. I'll look into the tripod.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Assuming that you are referring to a video clip then there are two techniques that you might explore:TT814 wrote:Is there a way to make it look smoother
1. Use of the Mercalli filter
2. Use of the Variable Speed option on the clip
tletter
I had thought of the variable speed control and was originally going to suggest it. But then I thought you could end up with an even wider variety of speeds in the one clip. But I guess getting pretty close is better than having some parts more obviously faster or slower.
Does Mercalli work with speed? I have only ever used it to largely remove shakes...
TT814
Thanks for the responses. I researched the Mercalli filter and with the version that comes with WSP 2018 Ultimate, it removes shakes but doesn't correct panning speed. I'm going to try the Variable Speed option, and see what I can do. If I have any success, I'll post it.
tletter
Having never seen your video, I've no idea what all the issues are, but there are probably several issues at play that ought to be corrected.TT814 wrote:I researched the Mercalli filter and with the version that comes with WSP 2018 Ultimate, it removes shakes but doesn't correct panning speed.
Mercalli V2 Plug-In "Eliminates jitter in video, even in zoom/pan moves".TT814 wrote:Is there a way to make it look smoother
tletter
TT814
I already used the Mercalli V2 plugin to eliminate the jitter in the panning, and that worked fine. However, it doesn't also smooth out the uneven panning speed, which is what I'm trying to do. Thanks for taking the time to offer help.
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Variable Speed is the best tool in VS2018 but will take some finess. You would need to clip the segment with the speed changes then use Variable Speed to set key frames an asign a value, slower or faster, and build your speed profile - up, down, steady, up, down, etc.
It will take some time and not be perfect but it could be an improvement.
TT814
Thanks so much for the details. I'll take the time and see how it works. I'll post back if it makes a real difference.
I am not on the pc to check but you may have problems applying Mercalli then Variable speed
changing the frames using variable speed may force Mercalli to rescan
You may have to apply Mercalli, render the project then apply Variable
Variable first the Mercalli may work, still think there may be problems
tletter
The Mercalli video analysis must be executed after all filters that affect the timing or size of a clip are applied. That being said, Mercalli and the Variable Speed option are compatible in my experience.lata wrote:you may have problems applying Mercalli then Variable speed
tletter
