I'm not sure what to do. My video files output is really bad quality. I always match these settings by selecting same as first video clip. I have tried all the other 4k pre set formats that videostudio offers, but still the output is awful quality. I have done the same in hitfilm video editor and the video quality is as it should be like the original! So it's something Corel does to my videos. Any idea would be greatly appreciated!
Original video settings:
PAL (25 fps)
MPEG-4 Files
24 bits, 3840 x 2160, 25 fps
Frame-based
H.264 High Profile Video: 69999 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
4K X10 Output Quality
Dolphiness
Re: 4K X10 Output Quality
I believe there was another poster with a similar issue, although not sure at the moment which version?
Using Smart Proxy files seemed to be the culprit
Can you remove the Proxy files then try rendering to same as first clip.
Settings Smart Proxy manager – File manager.
Does that improve the quality.?
Post updated
viewtopic.php?f=1&t=64008
Post updated
Dolphiness
I will try that and let you know! Thank you!
Dolphiness
Thank you so much Trevor! That did the job! I wish I would of ask earlier
Phil
- processor: 8 Core AMD
- ram: 32GB
- Video Card: Radeon R9 4GB
This appears to be a fault overall with VSP 2018. I'm outputting to 1080p from 1080p and with one Colour Balance FX, the resolution is really bad. I've had VSP since x3 was issued but this proxy problem is a fault that's new. The output looks like standard definition instead of high definition.
After trying various outputs, Smart Render on/off, same as first clip etc etc, it seems there is an underlying fault.
If deleting proxies is the workaround, that's no good when you want to go back into the project and make more changes.
Just FYI, we have raised this problem with our Corel contacts, who say they are working on a fix. But as usual we have no timeline for when this might appear.
Phil
- ram: 32GB
Thanks Ken. It appears that disabling proxy mode is sufficient rather than deleting proxy files.
Jan
- motherboard: ASUSTeK MAXIMUS IX HERO
- processor: Intel Core i7-7700K 4.20GHz
- ram: 16 GB
- Video Card: ASUS NVIDIA GeForce GTX 1060 6GB
- Hard_Drive_Capacity: 6.5 TB
- Monitor/Display Make & Model: Samsung TV 40" 1920 x 1080
- Corel programs: CVS 2020 version 23.2.0.587
Ken, glad to hear that Corel is eventually working on a fix. As far as I am concerned I didn't receive any answer after my second e-mail to Corel support about this bug.
Dolphiness
I'm glad I got the quality output now I'm deleting the proxy files, but like you said it's a real pain the .... when you want to work on the file again. I will try and just disable the the proxy, like suggested. Hopefully that does the job.
