Aftershot Pro and LR Dehaze
Claim
- ram: 8Gb
- Hard_Drive_Capacity: 712Gb
- Monitor/Display Make & Model: HP Envy 13inch laptop 4K display
- Corel programs: Corel Draw Suite 2018 , AfterShot Pro 3
Is there a preset or plugin were I can easily control the Dehaze function that LR has?
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: Aftershot Pro and LR Dehaze
Try to use the build in perfect clear / and / or local contrast / autocontrast (curves tool).
Also try the plugins Bez, wavelet sharping.
Local contrast can only be used on the main layer.
All other tools can also be used on an adjustment layer where you have better control concerning zone and power (transparency)
Then you may save a combination that is fine for you, as a preset.
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
IMFutureTrends
- motherboard: Acer Aspire F15
- processor: Intel i5-7200U
- ram: 8 GB
- Video Card: Vidia GEForce 940MX
- Hard_Drive_Capacity: 56 GB
- Monitor/Display Make & Model: SamSung LED 2450
- Corel programs: Paintshop Pro 2018, After Shot 3
May I ask for a clarification?
I did not know and cannot find any layers in AFS. If I send images to Paintshop Pro (or I assume you send to LR), then I can have many layers.
What do you mean you can only make adjustments on the main layer in AFS?
Peter
Nikon D7500, Olympus Stylus 6000
Peter
hannes_hab
- System_Drive: Z
- ram: 16 GB
you have to create layers
there area many many tools - most of them may be used on all layers - but some of them (e.g. local contrast only work on the main layer)
best way - play a little bit and use the manual as first help ...
https://www.aftershotpro.com/en/product ... /#learning
regards Hannes
austria
austria
