pspimage
jimbrennan
processor: AMD Six Core
ram: 16 GB
Video Card: NVidia GeForce GTX 750
Hard_Drive_Capacity: oodles
Monitor/Display Make & Model: Acer
Corel programs: Aftershot 3 PaintShop 2018 Painter 2016
pspimage
Post by jimbrennan »
Does Aftershot 3 support pspimage files?
If PaintShop only saves layers in pspimage, AfterShot is of limited value to those of us who always use layers.
hannes_hab
operating_system: Linux
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Re: pspimage
Post by hannes_hab »
APS is a raw-converter - it does not support native Paint-Shop, Photoshop or Gimp Files (with layersupport). Its the same with e.g. lightroom or other raw converters.
ASP should be the first step - most of the time there should be no need to use further editing - if there is the need to do so you con export as 16 bit tiff and edit with Raint-Shop Pro (or another external editor you want to use)
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
jimbrennan
ram: 16 GB
Re: pspimage
I use a raw-converter to create and, to some small extent, edit TIFF files. From there I can open it in Painter, PaintShop, AfterShot, Photoshop, Lightroom or Qimage. I never use native file types as TIFF is a no fuss format for me. After using the most appropriate programs, I can send the layered TIFFs back to Qimage for printing with specific paper-printer profiles. I can't do that with pspimage files. If a layer change is required, I simply open the TIFF, alter the layer and save it again. I was hoping to replace Photoshop and Lightroom. The only thing keeping me from doing that is the pspimage file limitation.
hannes_hab
System_Drive: Z
ram: 16 GB
Re: pspimage
I am not sure, but I think I understand your special needs - you have many old layered files that you want to reedit.
I have worked with photoshop, gimp (still working - but very seldom),eclipse , photivo (raw), pixeluvo, neat-image, noise-ninja (only noise reduction), photoprint (on linux) and Qimage (only for special prints on windows).
99 % ASP - don't need the other things - sometimes eclipse (for special compositings). I know it could and should be better, but after all nowadays its still the best choice (for me)
The main ting for a raw converter is to use it with raw file straight from the camera. 16 bit tiff are also fine but its not the original ...
regards Hannes
austria
jimbrennan
ram: 16 GB
Re: pspimage
They aren’t old files for me, layers are a major feature of the program. I practically always use layers. I just watched a video with Bob Taylor on using PaintShop on the Corel site and he recommends using layers as well - https://learn.corel.com/tutorials/using ... ro-part-1/.
Opening an old file in a raw-converter to make some small tweak is a bit of a lazy shortcut. But I do it.
As always, thanks.
iNate
motherboard: ASUS GL503VD
processor: Intel i7-7700HQ
ram: 32GB
Video Card: Nvidia GTX 10xx
sound_card: Realtek
Hard_Drive_Capacity: 250+512GB
Monitor/Display Make & Model: ASUS 15.6" + HP 24" 1080p IPS Displays
Corel programs: PSPX9, VSX9 Pro, VS2018 (Refund), WPOX7
Re: pspimage
Post by iNate »
AfterShot does bitmap files which are not RAW. JPEGs are an obvious example.
But PSPImage is probably asking for much :-)
