Can you scale layers in PSP 2018
Slipp
Corel programs: PaintShop Pro Ultimate 2018
Post by Slipp »
Does anyone know of a way, specifically in PSP 2018, to lock the aspect of layers when scaling by entering numbers? I know about dragging corners, but I'm looking for a way to enter a number once for both dimensions for precise changes.
LostNow
Corel programs: PaintShop Pro 2018 Ultimate
Re: Can you scale layers in PSP 2018
Post by LostNow »
If you only want to deal with one layer, be sure you are on that layer, then, under Image, select "Resize". Here you will have options to resize (up or down) by pixels, percentage, print size, or based on one side. You may also choose to check "Lock to aspect ration" or not, and immediately below is where you would check to "Resize all layers" if that is what you want to do.
Hope this helps!
Gini
