Wish List for PSP 2020
Rick_R
- motherboard: ASUSTeK Computer INC F2A85-V Pro
- processor: AMD A6-6400K APU
- Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
- sound_card: On-board Realtek and AMD High Definition Audio
- Hard_Drive_Capacity: 16TB+375GB
- Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
- Corel programs: PaintShop Pro 12-2022 Ultimate
Re: Wish List for PSP 2020
Optionally (i.e., user-settable), floating Palettes and Toolbars automatically move out of the way when editing. (For convenience, "T/Ps".)
I use two 39-40" TV's as monitors, mainly for photo retouching. When I scroll to magnify an image it often extends to under T/Ps that were off to the side at lower magnification--and then I have to rearrange them because they're on top of the area I need to work on. When I move to a different part--I have to rearrange them again.
There would need to be a way for PSP to know when the user is moving to a position to edit--so move T/Ps--versus moving to a T/P at that position to use the T/P.
I was thinking maybe a toggle hot key--press F10 to tell PSP "don't move T/Ps" or "resume moving". But I have the feeling we would regularly forget to press the toggle. Possibly an auxiliary key that overrides "automatically move" only while it's pressed--the same way holding down the space bar while dragging the cursor changes the function to "scroll image". If the cursor winds up on a T/P while the key is pressed, "automatically move" will be disabled until the user leaves the T/P.
Also, possibly a range setting for how much to move, because that would depend on the user's monitors. Obviously, on a 40" monitor you don't want to move 1-1/2 inch and on a 22" monitor you don't want to move 10 inches.
Troy at TheGTAMblog
- motherboard: Gigabyte 970A-DS3P
- processor: Intel i3-8300
- Video Card: NVIDIA GTX 1060
- sound_card: Creative Labs Tactic Alpha 3D THX Certified
- Hard_Drive_Capacity: 11TB total
- Monitor/Display Make & Model: Dell 2407WFP
- Corel programs: PaintShopPro, VideoStudio
1. Windows Icon EXPORT
256x256 or 512x512 .ico format export, for use in Background/Desktop Icons (Windows Shortcuts)
Currently, it does not even have the format selectable/available. BMP output is possible but the icon is very small (incorrect size)
Please look at Open Source application The GIMP to see how it handles ICO format (Windows Icon output) as it works very well
2. Input as Layer
Direct OPEN to an image, applying it as a Layer (in one step/function)
Currently, a user must open an image, Copy the image, then go back to the original image, then Paste it in as a Layer (4-5 steps vs 1 step)
Please look at Open Source application The GIMP to see how it handles Open Image As Layer, as it performs this function
Still pleased with PSPro and how it continually improves - keep up the great work!
2. Input as Layer
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
We already have tools to make custom shapes. Do you have something specific in mind? Tools you're familiar with from other software as an example of something we lack in PSP?
jdXp
- motherboard: Gigabyte EX58-UD5
- processor: Intel i7 950 3.07GHz 4 Cores
- ram: 12 GB
- Video Card: NVIDIA GeForce GTX 970
- Hard_Drive_Capacity: Multiple
- Monitor/Display Make & Model: Samsung SyncMaster 2494HM
- Corel programs: PaintShop Pro 2019 Ultimate
Just said bye bye to Adobe CC because I could not justify the subscription cost as a retiree hobbyist.notyou87 wrote:Layered EPS files. It merges all layers when you open an EPS file, would be great if that did not happen
I now have a folder full of EPS files from Illustrator that I might be able to open in 2020 with PSP.
Hopefully PSP 2020 will have the ability to open layered EPS files.
Chipoelectrico
- motherboard: Asus roc
- ram: 8 gb
- Video Card: Getforce GTX 870M
- Monitor/Display Make & Model: Portatil 17"
- Corel programs: PSP XIX
Yo deseo que la herramienta texto sea tratada de una vez como se merece. Es lenta, la selección es malisima, no hay corrector ortográfico, y aunque las nuevas formas predefinidas están bien, quiero una herramienta texto totalmente independiente de los gráficos o fotografías, que cuando termine mi creación de texto, no tenga que preocuparme de volver a buscar colores, degradados, tramas,,,,, que tenia antes de empezar a crear el texto. Y aunque podemos aplicar toda la potencia del PSP XIX en la creación de textos, seria preferible una herramienta que te facilitara mas el trabajo, por favor, si para poner texto en un circulo arriba y abajo y que quede decente, tengo que crear una capa nueva y girar el circulo y ademas no queda alineado, pues se mete dentro del circulo. Por pedir, que no quede.
Google translate
I want the text tool to be treated once as it deserves. It's slow, the selection is bad, there's no spelling checker, and although the new predefined forms are fine, I want a text tool totally independent of the graphics or photographs, that when I finish my text creation, I do not have to worry about searching again colors, gradients, frames ,,,,, that you had before you started creating the text. And although we can apply all the power of the PSP XIX in the creation of texts, would be preferable a tool that will make your work easier, please, if to put text in a circle up and down and that is decent, I have to create a layer new and turn the circle and also is not aligned, because it gets inside the circle. For asking, that is not left.
Google translate
jdXp
- ram: 12 GB
I humbly suggest Corel ensure PSP 2020 Color Management Monitor Profile defaults to the "none" option or at the very least "sRGB Color Space Profile.icm" and if required during set up the program guides them through choosing the system monitor option, although for the life of me I cannot understand why you even have that option if it has the potential to distort the colors.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
A Create function like this. Yes, I know we can get the same effect in PSP with File>New from Template.
ADonahoo
- motherboard: Dell Inc. 0KWVT8 A03
- processor: 3.60 gigahertz Intel Core i7-4790
- ram: 24GB
- sound_card: Creative SB X-Fi Titanium
- Hard_Drive_Capacity: 13256GB
- Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
- Corel programs: PSP X7, X8, X9, 2018, 2019
When I open PSP today, I would like the Recent Files list on the File menu and the home screen to show the images I had open yesterday, not two days ago.
- ehume
I have just customized my installation of PSP 2018 by adding "Paste as a New Image" to all the non-Print context menus. We can customize our context menus. How cool is that?
I am looking forward to PSP 2020 -- it has enlargeable text. PSP 2019 has that but it is so bug-ridden and the Cut tool has not been fixed.
If I load the PSP 10 workspace I will keep my customizations but I will not benefit from new features. I know that some folks (maybe me some time) would want to use their old workspaces, but I like the new features -- PSP has grown since the JASC days.
So, what I would like goes beyond loading mere toolbars, but all customizations. I would like the option of loading an older Workspace as-is, along with the option to load the old Workspace augmented with the new features. Then I could save my new Workspace with all the old customizations and the new features together.
Doing the above would save me loads of time. When I went from PSP x9 to PSP x10 (2018) I had to re-create my old toolbar. When I used a trial of PSP 2019, the prospect of re-doing my customizations predisposed me to want to buy it only if the new features were overwhelming. They were not and I did not.
Rick_R
Export and import custom toolbars.
For instance, I have a "Newspapers" toolbar in X9 and a "Book Scan" in 2018. I saved each workspace and was able to import them into 2019. But I can't have both toolbars in the same workspace without manually recreating one.
Submarine_dbk
- System_Drive: D
- Corel programs: Corel
Return the "Find People" feature (no longer available in PSP 2019). Adding a person manually requires 4 clicks and when your collection has literally tens of thousands of photos the lack of automatic face recognition makes the "People" feature virtually impossible to leverage (if I am missing something or if there is a workaround to activate "find people", please please please let me know how - Thanks!)
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
In Layers palette, drag the background layer inside the target image and it is done.... in one click...Troy at TheGTAMblog wrote: 2. Input as Layer
- ehume
A Restart button for PSP.
Otherwise, we have to wait for PSP 2018 64-bit to close, and without a stopwatch that is hard. BTW -- 32-bit PSP seems to be restartable as fast as I can do it.
- ehume
Customize: add Recent Files to what can be placed as a button. As of now in PSP 2018 Recent Files does not show up in the Customize window.
ADonahoo
- ram: 24GB
And have the Recent Files, show the last ones I had open, not the ones from the time before.ehume wrote:Customize: add Recent Files to what can be placed as a button. As of now in PSP 2018 Recent Files does not show up in the Customize window.
