How to use Perfectly Clear in PSP 2019?
cnstjoe
Corel programs: Paintshop pro 2019 Ult.
Re: How to use Perfectly Clear in PSP 2019?
Post by cnstjoe »
I was getting the error while loading also, these are the steps I took to fix it.
1: Removed vcredist_x64 2017 using add/remove from control panel
2: Installed vcredist_x64 from C:\Program Files\Corel\Corel PaintShop Pro 2019 (64-bit)\PlugIns\EN\Perfectly Clear SE v3.5\PCPlugin "it installs VC-2015"
3: Re-installed Athentech_PerfectlyClear_2019.exe using "Run As Administrator"
4: Restarted PSP2019
everything is working great now
btw, reinstalled vc-2017 later, everything still working
Timba
motherboard: Hewlett-Packard 1411 KBC Version 57.35
processor: 2.53 gigahertz Intel Core i5 M 460
ram: 4GB
Video Card: ATI Mobility Radeon HD 530v
Hard_Drive_Capacity: 303.64 Gig
Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis, January 2009)
Post by Timba »
Similar situation here:
I do see Authentech PerfectlyClear SE 3 in the pull-down within PSP2019, but keep getting this error. On a side note, the very first time I installed this plug-in, it worked! Then once I rebooted, the plug-in fails and I continue to get this error message. I've researched and researched, checked and double-checked the file location settings in PSP2019 to ensure the locations are added/corrected, trying re-installs from the plugin directory, etc. but to little avail. Any advice would be helpful. Thanks, -Tim
Timba
ram: 4GB
Post by Timba »
I just posted on another page associated with this subject. However, I want to create an update connected with the Perfectly Clear SE 3.5 install not functioning with PSP2019. I tried just about everything until I found that Authentech had a FREE (but less functional than the provided SE version purchased with PSP2019 Ultimate) PerfectlyClear ver 3.0 found at https://www.athentech.com/get-perfectly-clear-free. I installed this version also. As a result, it apparently fixed the issues involving missing files from the SE 3.5 install. While I now see both plug-ins from the PSP2019 plug-in pull-down menu, I can at least launch the version I want within PSP2019. Odd, but that's my story. -Tim
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
Timba wrote:I just posted on another page associated with this subject. However, I want to create an update connected with the Perfectly Clear SE 3.5 install not functioning with PSP2019. I tried just about everything until I found that Authentech had a FREE (but less functional than the provided SE version purchased with PSP2019 Ultimate) PerfectlyClear ver 3.0 found at https://www.athentech.com/get-perfectly-clear-free. I installed this version also. As a result, it apparently fixed the issues involving missing files from the SE 3.5 install. While I now see both plug-ins from the PSP2019 plug-in pull-down menu, I can at least launch the version I want within PSP2019. Odd, but that's my story. -Tim
Thanks for the link. My PSP 2018 came with Perfectly Clear SE v3. The new free plugin Perfectly Clear v3 has, in addition, a Dehaze function. Do not install PC Essentials: it requires "activation," which costs $49.
ehume
processor: i7 4770k
Post by ehume »
cnstjoe wrote:I was getting the error while loading also, these are the steps I took to fix it.
After installing and uninstalling PCE, the PCSE3 (not 3.5, which won't run on PSP 2018) gave me the same error message that Timba posted. My standard workaround is to close my image, close PSP 2018, run the PCSE3 installer again, reopen PSP 2018 and reopen the image. Many steps but it doesn't take long. But now I am intrigued. What is the "add/remove from control panel?" I would like not to have to run my workaround periodically.
davmurimd
motherboard: ASUS H87 PLUS
processor: Intel Core i5 4570 Quad Core 3-2 GHz
ram: 8 GB
Video Card: AMD Radeon R7 360 Series
sound_card: AMD High Definiton Audio
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: DELL U2415
Corel programs: Paintshop Pro 2021U
Post by davmurimd »
I would like to add my thanks for the suggestion to use the free version. I also installed the Free version of Perfectly Clear v3. This enabled Perfectly Clear SE 3.5 to run, but with one problem This is that at the the free version has to be started first, then cancelled, after which the SE version will run properly until the PC is restarted when the free v3 has to be started and cancelled again. I wonder if anyone else has encountered the same issue and may be able to suggest a solution? - David
ehume
processor: i7 4770k
Post by ehume »
I discovered two things:
1. Where PC3 worked perfectly, PCSE 3 showed an "Access violation." So I closed PSP, went to my Distrib folder, went into Corel/PSPx10 (that's now PSP 2018) and reinstalled PCSE 3.0. Then it worked.
2. When I got PCSE 3 to work, it too has Dehaze under "Perfect Exposure."
