How to use Perfectly Clear in PSP 2019?
pledden
motherboard: Micro-Star International B360 GAMING PLU
processor: i7_8700K
Video Card: NVIDIA GeForce GTX 1050
sound_card: On board
Hard_Drive_Capacity: 3500GB
Monitor/Display Make & Model: Dell 24" Ultrasharp
Corel programs: PSP 2022, Video Studio X10, After Shot
Post by pledden »
I have installed both 32 & 64 bit PSP 2019 plus After Shot and Perfectly Clear but I can find no trace of Perfectly Clear after opening PSP 64bit with a graphic?
Windows 10 64bit
Peter Ledden
Kathy_9
Hard_Drive_Capacity: 2TB
Re: How to use Perfectly Clear in PSP 2019?
Post by Kathy_9 »
Did you check under Effects - Plugins - Athentech?
When you go to Effects > Plugins do you see Athentech? If you do, then click it and you should see Perfectly Clear...
pledden
processor: i7_8700K
Post by pledden »
Thank you Ken & Kathy. Now I know where it is it won't work.
Peter Ledden
Kathy_9
Post by Kathy_9 »
I just tested it and it works fine so it's not across the board. Have you tried uninstalling and reinstalling Perfectly Clear?
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
No problem here with Perfectly Clear - works in 64 bit version , does not appear as a choice in 32 bit version. There was a 32 bit version of Perfectly clear offered back with PSP X6 (which was the first time PSP came out in a 64 bit version)
On the other hand the other Pic to Painting appears in the 32 and 64 bit Effects versions but gives an error in the 32 bit and works well in 64 bit version.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I wasn't aware that PSP2019 was available, as I don't see it on the Corel site. :?:
JoeB
Using PSP 2019 64bit
pledden
processor: i7_8700K
Post by pledden »
Kathy_9 wrote:I just tested it and it works fine so it's not across the board. Have you tried uninstalling and reinstalling Perfectly Clear?
The strange thing is Kathy is that there is no .EXE file for it so my Revo Uninstaller can find no trace of it and yet it is listed in Effects/Plugins. I wish I could uninstall and reinstall.
Peter Ledden
hartpaul
ram: 8 Gb
Post by hartpaul »
@ Joe --Ahh the advantage of having the advertising turned on! :D :D :D
But I received an email advertising the Upgrade.
Heading
NEW! PaintShop Pro 2019 Ultimate has arrived! [Special Offer Inside]
Special early access to exclusive savings
and Offer expires 31 August.
You might check your junk mail filter
hartpaul
ram: 8 Gb
Post by hartpaul »
I have it as an .exe file
PSP2019_Athentech_PerfectlyClear.exe 70819 KB
and it does appear in the app list and can be uninstalled from there.
Settings > Apps and scroll down and it is under Athentech Perfectly Clear
And you'll find that in C:\Program Files\Corel\Corel PaintShop Pro 2019 (64-bit)\PlugIns\EN\Perfectly Clear SE v3.5
JoeB
ram: 8 GB
Post by JoeB »
If it's a .exe file then that sounds like a standalone version, not a plugin.
JoeB
Ken Berry wrote:And you'll find that in C:\Program Files\Corel\Corel PaintShop Pro 2019 (64-bit)\PlugIns\EN\Perfectly Clear SE v3.5
I should clarify that I don't have an exe file located there -- just the expected PerfectlyClearSE 8BF file.
I had been assuming that hartpaul was referring to the Athentech_PerfectlyClear.exe file which was downloaded as part of the installation package for PSP 2019. In other words that exe file is an installation file for Perfectly Clear and in my case, all that is installed is the 8BF file.
hartpaul
ram: 8 Gb
Post by hartpaul »
Ok just to try and clear up the confusion.
This shows the files I downloaded from Corel when I purchased PSP 2019 and after I installed it
The first folder 'PSP2019downloadedinstallation' contains:
psp2019_ult folder and psp2019_ult.zip which contained all the local set up files stored in that folder. I collected those and placed them in the first named folder.
AKD-73664734352.pdf contains the order details converted to a pdf and PSP2019Info.rtf contains the licence keys - both created by myself.
So photomirage_express.zip down to PSP2019_Ult.exe were the files downloaded from my Corel order.
The Perfectly Clear is an installation .exe file which installs all the needed files for it to run as a plug in.
This next diagram shows those Perfectly Clear 3.5 files which are a bit more than just an .8bf file
Now I hope that is perfectly clear.
JoeB
ram: 8 GB
Post by JoeB »
hartpaul wrote:@ Joe --Ahh the advantage of having the advertising turned on! :D :D :D
I was just curious. :-) I have never gone for a pre-release version, because I'd rather follow the pre-release version posts and see what's improved and what's broken - and then wait to see if Corel fixes at least the most important parts of what's broken before they launch the retail release. :-)
So far I gather that they haven't fixed what has been a very major complaint all year - i.e., they haven't fixed the crop tool or even made it an option to use the previous versions of it. If that's true, it's likely an indication that they have once again done more simply cosmetic improvements rather than stuff that users really care about and what users have asked for. Probably because doing the latter would take some actual thinking and effort put into programming.
JoeB
