Videostudio 2018 constantly crashing when in Sound Mixer
titan3025
Post by titan3025 »
I am having trouble with VS 2018 when I am in the sound mixer tab and I am trimming video clips and then playing the project from time to time to see how the audio video sync looks like.
After a few trim operations the whole program is crashing when I hit the play button. Exactly in the moment when I hit the play button.
I am running version 21.3.0.141
titan3025
Re: Videostudio 2018 constantly crashing when in Sound Mixer
Post by titan3025 »
This is the error message I see in the Windows Event Logs:
Faulting application name: vstudio.exe, version: 21.3.0.141, time stamp: 0x5b3fa05a
Faulting module name: ntdll.dll, version: 10.0.17134.165, time stamp: 0xf4df6dc2
Exception code: 0xc0000374
Fault offset: 0x00000000000f4d1b
Faulting process id: 0x3d58
Faulting application start time: 0x01d42bd6ac33f020
Faulting application path: C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: a8f0def9-43ac-4e21-be7c-1d40de676459
Faulting package full name:
Faulting package-relative application ID:
cds
Corel programs: VideoStudio 2018 and others
Post by cds »
Seems to be a feature in this version - I experience similar things, but for me crashing is not limited to hitting play - but occurs most often there.
I got the impression that this happens when VS is still doing "something" in the background and then a new operation is started.
The exception code indicates a heap corruption - which could be some bad implemented background task operation ...
Hi titan3025
Can you give more details as the type of video clips you are working with.
Better still to provide a sample or two, you would have to upload to a sharing site, google drive etc.
I have tried using my own MTS video files with the Sound Mixer, cutting, moving playing in both Clip and Project mode, no crashes………….
I have also tried editing the libraries audio clips again using the sound mixer.
titan3025
Post by titan3025 »
lata wrote:Hi titan3025
These are video clips from a GoPro hero 5. Just the straight out of the camera files.
Are you able to upload a few samples to a sharing site, then we can test the files to see if we can replicate the problem
otherwise please re-install the program to see if that improves things?
titan3025
Post by titan3025 »
Hi Trevor,
I reinstalled the application and I found out what is causing the crashes. It is the option "Enable hardware acceleration optimization" in the performance preferences. Since I disabled it it runs without these crashes. Somehow this option must mess with the sound mixer (or the windows drivers).
I am running VS 2018 on a Suface Pro 2017 with a plain original Windows installation and drivers as the Surface comes.
Cheers
Matt8890
motherboard: MSI Z370 Pro
processor: Intel Core i7 8700
Video Card: Intel UHD360 and NVIDIA GTX1050
Corel programs: Videostudio Ultimate 22
Post by Matt8890 »
I have experienced this also with Realtek ALC892 sound card. I found Windows 10 used its own drivers, so I disabled them and installed the Realtek ones, the sound mixer crashing kept happening until I also disabled all hardware optimisation. For now that seems to have solved the problem. Just turning off optimisation for performance was not enough
