Stack and Unstack greyed out
eja
operating_system: Mac
Post by eja »
I have contacted Corel support numerous times and they have been zero help. My images have been imported into a catalog and yet I can not use the stack and unstack command. It is greyed out. The only thing not greyed out is roll/unroll. Does anybody else have this problem? Can anybody clarify the proper use of this function in case I am attempting to use it incorrectly? Yes, I have read and reread the help file. I have attempted the procedure in the helpfile. It still will not work.
Also, I recently went back and used my version on my mac. It is doing the same thing as above. This could be user error or it could be a bug in the program, but nobody on this board has clarified and tech support can not clarify either. At this point, unless I can get better information, I am assuming this feature does not work.
Also, I have been working with tech support since 26 July 2018 on this issue.
Thanks in advance.
hannes_hab
operating_system: Linux
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Re: Stack and Unstack greyed out
Post by hannes_hab »
Try to change "recursive catalog view" to off - the it works also for other stacks - if "recursive catalog view" is on only a "version stack" can be rolled and unrolled
It ("recursive catalog view") also affects arranging of images: "A stack can be moved around like any other selection of images, and
the order of the images in a stack can be arranged by dragging the images/versions to the desired placement within the stack. That arbitrary ordering will not work when the recursive catalog view is active." (from AS Survival Guide)
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
hannes_hab
System_Drive: Z
ram: 16 GB
regards Hannes
austria
eja
Post by eja »
Thanks for the reply regarding stacks. I can't find how to set the recursive view to off or on. I followed the link posted also but could not figure out which video is discussing the stacking feature. I also could not find this setting in the help file.
hannes_hab
System_Drive: Z
ram: 16 GB
click on it to switch on and off
regards Hannes
austria
eja
Post by eja »
Hey, that worked. Thank you for your help. I don't understand why the Corel support team could not give that answer. Thank you so much.
