Borders
Billynz55
Hard_Drive_Capacity: RD2 Whanga
Corel programs: Paintshop Pro 2018 trial
Borders
Post by Billynz55 »
I am a new user. Have experimented with add borders. Now I would like to delete/remove some from my photos. Need help with this. Some are pretty awful. Thanks.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Borders
Post by hartpaul »
Easy. You delete the image and re do again from the original.
or the saved copy before you added a border.
You did work on a copy didn't you???
If unfortunately, it is the only copy of the image that you have (Always back up, always work on a copy) then the only way you can remove a simple border is to crop the image so the border is no longer there.
If most unfortunately, you used one of those complicated borders (Picture Frames - getting in before you experimented with them) that intrude on your original image then you can never get back the information that was wiped out when the border replaced that edge information.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Borders
Post by JoeB »
And not only should you be working on a copy of the image while keeping the original, you should be working on layers on the copy and saving the image first in .pspimage format so that you have all of the layers, selections, etc., intact for future use if you want to change things or delete some additions you made originally.
When I open an image the first thing I do is promote it to a regular raster layer and duplicate that layer. That way I'm starting by working on a duplicate copy of the original. If I save that - as well as any changes I make - as a .pspimage then not only is the original .jpg/png/tif or whatever still not touched but I have a copy of it, untouched, as the bottom layer in the stack below the layers on which I did my manipulations.
JoeB
Using PSP 2019 64bit
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Borders
Post by LeviFiction »
Add Borders flattens the image. Which reminds me I was working on an alternative to that. I should get back to that.
JoeB
ram: 8 GB
Re: Borders
Post by JoeB »
LeviFiction wrote:Add Borders flattens the image. Which reminds me I was working on an alternative to that. I should get back to that.
I didn't realize that. And it's a pretty silly way to implement that feature IMHO. Yes, an alternative would be a great idea!
JoeB
hartpaul
ram: 8 Gb
Re: Borders
Post by hartpaul »
Perhaps a wish list for 2020. Picture frames does not merge the files and adds the frame as a new layer (just learned that by testing it so my warning about using frames was wrong) .
Make 'Add Borders' add the borders on a new raster layer and have that as an option as the auto merge does save a couple of steps as you manually merge it.
Billynz55
Re: Borders
Post by Billynz55 »
Thank you all. I was hoping for a more elegant fix. Did the revert to original. And duh..... I didn't keep a copy so all editing was lost. Had thought a complete history was saved. But if image is flattened that wouldn't be useful. Thought about cropping and will go that route. Yes a change to how Borders are implemented is essential. Using the trial version and until this was in no doubt about buying. Thanks again. Billy.
JoeB
ram: 8 GB
Re: Borders
Post by JoeB »
hartpaul wrote:Perhaps a wish list for 2020. Picture frames does not merge the files and adds the frame as a new layer (just learned that by testing it so my warning about using frames was wrong) .
I believe that there are a couple of older scripts that can add borders on new raster layers - maybe one by Suzshook - but I'll have to search for them when I get a bit of time. Kinda busy with a video project at the moment. :-(
JoeB
