Help with Color Changer
pixelblu
motherboard: Gigabyte
processor: i7 4790k
Video Card: Intel HD Graphics 4600
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: LG 32"
Corel programs: PSP 2018
Post by pixelblu »
Hello -
I'm trying to do a very basic color change using PSP 2018 on a graphic that has straight lines and solid color . When I make the change there is always a very fine border around the edges of the underlying (previous) color. I've made sure the palette has both the foreground/background and stroke selected with the same color but can't seem to get it to fill out to the edges. I've also trying playing with the tolerance but it has no affect of the edges. If anyone has any suggestions on what I might try I would appreciate it.
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: Help with Color Changer
Post by flagpole »
Without seeing the image it's difficult to say...
But you might be better adjusting the colour from the colour wheel adjust - colour or something like that. Or hue to target.
pixelblu
processor: i7 4790k
Post by pixelblu »
Thanks for the suggestion...I just tried using "Adjust -> Hue and Saturation -> Colorize" and that seems to work better but still has some bleed through on the borders
flagpole
Post by flagpole »
I was actually thinking of the Hue/Saturation/Lightness above Colorize.
Would probably help to see it.
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
You could try:
http://vicanek.de/imageprocessing/colorreplacer.htm
I find that a lot easier than the PSP version :-)
Joëlle
Joëlle
(PSPX9 )
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
pixelblu wrote:Hello -
Could you post a crop of your image ?
It is difficult to give a correct suggestion without seeing the problem.
pixelblu
processor: i7 4790k
Post by pixelblu »
Sorry for the delay in getting this posted but here's a before sample (blue) and the color change to a dark grey...you should be able to see the blue border bleed.
flagpole
Post by flagpole »
Just turn the saturation down.
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
Corel programs: PSP X8, Knockout 2
Post by TimW »
You could also use the Chromatic Aberration Removal tool found under the <Adjust> pull down menu. Desaturation works very good if you change a color to black or grey. Chromatic Aberration Removal works no matter what color you change to.
pixelblu
processor: i7 4790k
Post by pixelblu »
I tried the Chromatic Aberration Tool but can't get it to work. Selecting the color to remove does nothing with the "Preview on Image" checked or in the "After" window. I looked through the instructions in the user guide and it doesn't look like I'm missing anything.
Kathy_9
Post by Kathy_9 »
Once you've made your selection, go to the Selection menu and use Modify - Expand. Start with 1 pixel and increase if necessary until you can flood fill with no outline color showing. You could also play with Modify - Inside/Outside Feather and select outside and manipulate the number of pixels as needed.
TimW
Post by TimW »
Pixelblu, you need to create or Choose a sample entry from the List of Samples area. Look in the Help section for "Chromatic Aberration Removal", there you'll find detailed instructions.
pixelblu
processor: i7 4790k
Post by pixelblu »
Thanks to everyone for the suggestions... I think I found a solution. After making the selection and using flood fill, I needed to be sure the "Match Mode" was set to "All Opaque". Blue bleed on the edges are gone :)
TimW
Post by TimW »
Several good solutions to the same problem - we all learn something.
Jean-Luc
Post by Jean-Luc »
pixelblu wrote:I tried the Chromatic Aberration Tool but can't get it to work. Selecting the color to remove does nothing with the "Preview on Image" checked or in the "After" window. I looked through the instructions in the user guide and it doesn't look like I'm missing anything.
An error is displayed in the settings window. The text says "click on the color" but clicking does nothing. You need to draw a selection, like attached, and it works.
