VideoStudio 2018 stops during rendering
JPSo
motherboard: Asus N750JK
processor: i7-4700 HQ
ram: 16 GB
Video Card: Nvidia GeForce GT850M
Hard_Drive_Capacity: 947 GB
Monitor/Display Make & Model: SAMSUNG T240 HD
Corel programs: VS X10, VS 2018
Post by JPSo »
The title explains my problem. After having changed VS X10 to VS 2018 ULtimate (SP3), when rendering a project, the encoding process starts normally and at about 45 % stops with the message :
Microsoft Visual C++
Assertion failed
Program : ...m Files\Corel\Corel VideoStudio 2018\UpScaling.dll
File : Upscale.cpp
Line : 593
Epression: SUCEEDED(hr)
For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts
(press Retry to debug the application - JIT must be enabled)
There I can choose "Abort", "Retry" or "Ignore". The two first close the program and if I choose Ignore, the encoding goes on until the next stop with the same message. I "ignore" several times (5 on a 45 mn film) but the result is awfull (whites burnt).
I contacted the Corel Support and I was told that the HerDoctordll.dll file was corrupt and I had to reinstall Windows 10 ! The HerDoctordll.dll file is located in Program Files\Corel\Corel VideoStudio 2018 ; I reinstalled VS 2018 it with the same result, so I don't see why it should be corrupt every time.
Has somebody a better idea ?
Re: VideoStudio 2018 stops during rendering
Welcome to the forum -- though I wish it were in happier circumstances.
It would help if you could tell us about the video in the project: exactly what format is it? Right click on one of the clips in either the VS timeline or VS library window and copy ALL of the Properties here, please -- or take a screen shot of the Properties box and upload it here as an Attachment.
Is the format you are rendering to the same? I ask since the the defaulting module is UpScaling.dll, which tends to suggest that the original video in the project is being upscaled to something different, either in size or quality.
JPSo
ram: 16 GB
Post by JPSo »
Here is the MediaInfo file of one clip. All are similar. The rendering format is "Same as first video clip" ; Smart Render is enabled. There is no upscaling of a clip except some zooms with antishaking Mercalli.
Général
Complete name : E:\TdM_2018\Japon\P1050226.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/avc1)
File size : 26,8 Mio
Duration : 8s 160 ms
Overall bit rate mode : Variable
Overall bit rate : 27,5 Mb/s
Encoded date : UTC 2018-04-23 14:40:01
Tagged date : UTC 2018-04-23 14:40:01
PANA : DMC-FZ300
Vidéo
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Oui
Format settings, ReFrames : 2 images
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 27,3 Mb/s
Maximum bit rate : 36,9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate mode : Constant
Frame rate : 50,000 Im/s
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressif
Bits/(Pixel*Frame) : 0.263
Stream size : 26,5 Mio (99%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : mp4a-40-2
Source duration : 8s 213 ms
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 canaux
Channel positions : Front: L R
Sampling rate : 48,0 kHz
Frame rate : 46,875 Im/s (1024 SPF)
Compression mode : Avec perte
Stream size : 124 Kio (0%)
Source stream size : 125 Kio (0%)
When you uninstalled 2018 check the folder “Program Files\Corel\Corel VideoStudio 2018”
To make sure it has also been removed, if not I would delete that before installing
That will make sure the new install uses a new file.
You can also run the Cleanup tool from here
viewtopic.php?f=1&t=59847
To install 2018 first rename the 64bit\Ultimate to Ultimate_old
That will cause the program to download the main program again, just in case the first download was corrupt?
Install an older version, deselect the option for Service Pack 3, will install an older release version of the program.
Does that improve things? If no then like Ken I would suspect the actual video files?
The Release Version included SP 2, as a separate install. SP 3 being released on the 10thJuly
JPSo
ram: 16 GB
Post by JPSo »
Solved.
I unisntalled all the previous VS programs with the Clean Up Tools, deleted all the Corel files (except mines, of course), emptied the temp folders, cleaned the Registry with CCleaner, re-downloaded and reinstalled VS 2018. I rendered again my project and ...it worked !
Thank you for your advices.
Jean-Pierre
Good news, glad you have things working.
Thanks for the update.
