Need Help - Collecting command data
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Hello,
I'm working on adding highly detailed documents on PSP commands and constants, this requires that I be able to compare how they have changed from PSP8 to PSP 2018.
I'm looking for volunteers who each have at least one of these versions of PSP to run a script for me:
PSPX2 (not 12.5)
PSPX3
PSPX4
PSPX7
Here is how this works: Video demo: https://drive.google.com/file/d/170T48v ... NsKLE/view
1) Download this script: https://drive.google.com/file/d/11aecNQ ... sp=sharing
2) Unzip it into your Scripts-Trusted folder
3) Edit the script to point to a folder such as your desktop or some other place you can easily find. The pathname must end with "\\" and each backslash in the path must be a "\\" as well. I demonstrate this with an example in the video.
4) Run the script - you'll get a MsgBox that tells you when it's done
5) Zip the two files together
6) Upload them either here directly or somewhere I can download them and provide the link
If this works like I'm hoping I will have a complete API for every version of PSP, along with details on what has changed between each version.
EDIT: Thank you CosmicDread for X5, X6, and X8. I greatly appreciate the effort you made in doing a fresh install.
cosmicDread
motherboard: MSI MPG Z390 Gaming PRO
processor: Intel Core i9-9900K
ram: 32 GB
Video Card: GeForce GTX 1080 Ti
Hard_Drive_Capacity: 6 TB
Monitor/Display Make & Model: Acer Predator X34
Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
Re: Need Help - Collecting command data
Post by cosmicDread »
Here is PSP X5 (15.1.0.10). I did a fresh install.
PSP X5 (15.1.0.10).zip
(100.32 KiB) Downloaded 148 times
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
cosmicDread
ram: 32 GB
Here is PSP X6. I did a fresh install of this one as well.
PSP X6 (16.0.0.113 x64).zip
(100.98 KiB) Downloaded 146 times
cosmicDread
ram: 32 GB
Here is PSP X8 (18.0.0.124 x64). This was another fresh install. I had to run the script twice. During the first run, PSP said there was a parameter missing. It worked fine the second run. I had renamed the files from the first run, so the second run did not get corrupted.
PSP X8 (18.0.0.124 x64).zip
(111.58 KiB) Downloaded 157 times
ram: 6 GB
Yes, that parameter missing happens on and off for me, I'm not sure if it's just the speed of the script or if it has to do with the renaming of AdjustmentLayerColorBalance to AdjustmentLayerWhiteBalance.
Thank you so very much for all of that work. I do greatly appreciate it.
