16:9 Format
ian.gill
16:9 Format
Post by ian.gill »
When ever I try to convert a vidio file in VideoStudio 7, it outputs it as a 4:3 aspect ratio even if the input file is 16:9.
Is there a way to set the output to 16:9 so I don't have a lot of tall thin people on my screen?
htchien
operating_system: Mac
Post by htchien »
Maybe you can try to upgrade your UVS.
Ulead VideoStudio - Upgrade:
http://www.ulead.com/vs/upgrade.htm
Hope this helps.
Rgrds,
H.T.
htchien
Post by htchien »
Post by Trevor Andrew »
As well as your video file being 16:9 ratio.
Make sure that your project properties are 16:9 ratio not 4:3
File/project properties/edit/general tab/display aspect ratio.
david reece
Post by david reece »
i wouldnt upgrade to VS8 as it has some major problems!
as to VS7 it doesnt support 16:9 ratio.
vz00424
I face the same problem using UVS 8
Post by vz00424 »
Whwnever saving 3:4 it is captured on the DVD as 16:9
chask
Post by chask »
Edit - Sorry - wrong thread post
