My vstudio.exe file disappeared this morning. I have been using it almost every day since June 30. I updated with a service pack 2 days ago. I'm pretty sure that I ran it after the upgrade. I tried to run it today and the exe file was missing.
I re-ran the installer.exe program from the install files & it ran for 1 minute & then said the software was installed. However the exe file was still missing.
I also ran the install.exe program (not sure what the difference between the two of these are) & it ran for 1 minute & then said the software was installed. However the exe file was still missing.
I then uninstalled vs 2018 and am in the process of re-installing (with newly downloaded files).
Has this happened to anyone else?
Also, when I ordered the upgrade I ordered the backup DVD I was going to look for the exe file on the DVD but realized that Cleverbridge never shipped it. anyone else experience shipping problems?
Berto
vstudio.exe file disappeared 2018 Ultimate
delaluz
- motherboard: HP Z210 work station
- processor: xeon E31240 3.3ghz quad core
- ram: 16gb
- Video Card: nvidia NVS 300
- Hard_Drive_Capacity: 6 TB
- Monitor/Display Make & Model: Samsung 24" Syncmaster
- Corel programs: Videostudio X9.5; Photoimpact X3
jpmorgan49
- Hard_Drive_Capacity: 2TB
Re: vstudio.exe file disappeared 2018 Ultimate
I had a similar problem this morning after update. I've sent a request to tech support to see if they can help. Below was the request:
"I opened Videostudio Ultimate 2018 and an update was available. I choose to update. It told me to close VS and continue and I did. During install it stopped on vstudio.exe and said it couldn't install because the file exists. I tried several times but it said the same thing so I choose ignore. When the update was complete I tried to start VS2018 and it said "vstudio.exe" was missing. I tried to reinstall but it said it was already installed and stopped. Is there a repair? I hate to uninstall and lose all my settings and media libraries. Thanks."
Nikon D7200 SLR
GoPro Hero 3+ Black
Corel VideoStudio Pro Ultimate 2018
GoPro Hero 3+ Black
delaluz
- ram: 16gb
I did a complete new install & it works now.
Hi jpmorgan49
I think you will have to re-install the program
The vstudio.exe file should be here
C:\Program Files\Corel\Corel VideoStudio 2018
When we install service packs I am sure this file is replaced, seems like something went astray.
You should report this to Corel Support.
If you save the folder 21.0, which holds your library structure.
C:\Users\Trevor\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\21.0
Just simply rename it to “21.0 old”
Re-install 2018, then replace the new 21.0 folder
As VStudio.exe is missing I think you may have to use the cleanup tool to uninstall, but first try program and Features.
I reported a couple of days ago when the SP first appeared that VS refused to work after installing it: viewtopic.php?p=358909#p358909
I didn't get a message saying vstudio.exe had disappeared, and didn't think to check if it had. I *did* get a msg saying that the path to that file could not be found or I was not authorized to use it. I removed all traces of VS from my computer and reinstalled. The reinstallation process included the new SP, and all is now working again.
delaluz
- ram: 16gb
BTW, I received the DVD today.
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
After installing the update, the exe file disappeared. On my Windows 7 computer no problems. After a complete reinstall, everything works. This mehtod of updating leaves a lot to be desired.
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Haven't had this problem, but I use a custom install location for both the download files and the software installation. Did note that the packages for sp2 and sp3 were in the C drive location, despite the custom location usage. After installing sp3, opening VS normally several times for project work without any issues, and the sp3 version number 21.3.0.141 correctly displayed.
wstagner
- motherboard: Gigabyte Ga-p43-es3g
- processor: Intel Core 2 Quad Q8400 2.66 GHz
- ram: 8gb
- Video Card: ATI Radion HD4300 4500 series
- sound_card: ATI High Definition Realtek ALC888 codec
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Asus VH242H 24" 1920x1024 screen.
Ditto that.
