Is there image stabilization?
Cyberherbalist
processor: ASUS Laptop
ram: 8 GB
Hard_Drive_Capacity: 17 TB
Monitor/Display Make & Model: ASUS
Corel programs: Video Studio 2023, PaintShopPro 2021
Post by Cyberherbalist »
I have drone footage that is rather shaky due to winds, and my amateurish attempts to control the drone. I have heard that some video editing software have tools that can stabilize these images. I can't find anything in VideoStudio documentation or the menu that says if it can be done, so I have to ask here. I know that YouTube can do it, but my upload speed is snailish, and I'd rather use VideoStudio if I can. I have VS 2018 Ultimate.
Can one stabilize video in VS? If so, how? Here's a test clip: https://www.youtube.com/watch?v=cKgqb7-YD-8
I tried to include this clip using the BBCode [youtube][/youtube], but couldn't make it work. How is it done?
Last edited by Cyberherbalist on Sat Jul 14, 2018 7:52 am, edited 1 time in total.
See my YouTubeChannel, A Yank in Sussex
bifer
processor: i7-4720 HQ 2.60 GHz
Video Card: NVIDIA GeForce GTX 960M + Intel HD4600
Hard_Drive_Capacity: SSD 1+2TB
Corel programs: ASP3, PSP2018 + VS2018 Ultimate
Re: Is there image stabilization?
Post by bifer »
Apply the FX filter Mercalli 2.0 and then experiment a bit with the different values ... Remember before you can see the result VS2018 is analyzing the footage ...
Cyberherbalist
ram: 8 GB
I hate to look ignorant, but I am ignorant so it's the truth. I see the FX in the Edit menu, but there's no Mercalli 2.0 there. I've found a YouTube video from Corel that says how to use Mercalli, but the only proDAD FX item I have is Adorage. There's apparently 4 others, but I don't have them.
This is Video Studio 2018 Ultimate.
First reset the program by renaming the folder 21.0 to 21.0_old
Run video studio will generate a new folder
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\21.0
If that does not work…
Locate your download installation files, by default would be on your desktop in a folder called Video Studio 2018. There will be a \64bit\BonusFeature
Do you see that folder?
Open the folder and double click setup_Bonus.exe
That will run the installer again to install the Ultimate package, prodad stuff.
Any improvements?
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Cyberherbalist wrote:Can one stabilize video in VS? If so, how? Here's a test clip: https://www.youtube.com/watch?v=cKgqb7-YD-8
This clip has a jello-like movement in addition to shake. Mercalli 2.0 will not remove video jello. In any event, once you have Mercalli 2.0 installed, you'll have to try each of the four 'Virtual Stabi-Cams' and adjust the available parameters to see which works best for your source videos.
tletter
Cyberherbalist
ram: 8 GB
lata wrote:Hi
No, this didn't work
lata wrote: If that does not work…
Any improvements?
I found a folder called C:\Program Files\Corel\Corel VideoStudio 2018
but there was no subfolder named \64bit\BonusFeature, and no file named setup_Bonus.exe.
Would the download installation files be located in the Download folder? If so, they have been deleted for space considerations. If this is where the installation files are supposed to be, I may have to download the application again. Might this be the case?
Normally the download process creates a folder on your desktop (labelled VideoStudio 2018) which contains all the necessary files. But by the sounds of it you might have cleaned any such folder in the same way you say you would have if it were in the Download folder. So yes, you would need to download the package again.
Personally, I not only leave the folder either on the desktop or move it to the Download folder, and I also copy it to an external hard drive for extra security, and include the SN with it too.
Cyberherbalist
ram: 8 GB
Thanks for everyone's contribution to this thread! Since my installation seemed to need refreshing, but I needed to redownload the installation, I went to Corel customer support and got some assistance from them. Turns out that I still had Corel VideoStudio X10 installed on my system and this might have caused the problem. The support person advised me to uninstall both versions and reinstall fresh. So, I am about to do this.
Aren't computers fun? :-)
You can download copies of the installation files at any time.
Run the Web Installer, choose a new Download Location
Deselect ---"Do not download installed modules again”
Choose “Download only”
let us know which files are available for you to download, thanks.
When you come to installing simply run the Web Installer again.
Not heard of X10 affecting 2018 in this way, we were thinking you had simply not installed the Bonus Features
tletter
Post by tletter »
Cyberherbalist wrote:Turns out that I still had Corel VideoStudio X10 installed on my system and this might have caused the problem.
Well the bad news for you is that Mercalli 2.0 is in the Ultimate version of both X10 and 2018. Hence upgrading to Ultimate 2018 will not upgrade this filter so you can test its effect by running Ultimate X10.
tletter
Cyberherbalist
ram: 8 GB
lata wrote:Hi
Had a very interesting experience with the re-installation.
The reinstallation succeeded -- finally -- but the first time I installed and ran VideoStudio it failed. I ran the installation again, over the top of the existing installation, and it succeeded. Although the Home screen is strangely blank when the application runs.
Here's what happened:
I uninstalled both X10 and 2018, and then used the cleanup tools to clean up the old installations. Then I downloaded the download installer, and ran it. The download seemed to go well, but when I tried to start VS 2018 Ultimate it only got as far as the splash screen. The splash screen showed itself for the usual amount of time, but once that was done it went away and nothing was happening. It was as if the program hadn't been started. I tried a few times, and got the same result. Since I am a retired computer programmer, I know to check the system Event Log to see what might have happened. The log showed that the application had started, but a failure occurred. The failure entry didn't tell me anything (it just gave an error code that didn't mean anything to me). Although I can tell that the exception occurred in the dynamic link library "ntdll.dll".
After I ran the installation again, I was able to get VideoStudio working, and all the features that were missing before were now available. The odd thing about it was the Home tab when the program opened. Here is what it looks like with the program running and the Home tab active:
It has been posted on the forum regarding the white screen, but that seemed to fix itself after a re-boot.
are you still having a problem.
Reset the program by renaming the 21.0 folder
more info here
http://lata.me.uk/corel/reset/reset.htm
When you installed from the web installer did that download a service pack, SP 3 is now available, I was just wondering if that was provided or the older SP2
I am doing a cleanup of my pc and at the moment do not have VS installed
I will be installing 2018, soon, so will take note of install process
Cyberherbalist
ram: 8 GB
lata wrote:Hi
more info here
Everything seems to be OK now. The white screen fixed itself after I stopped VS2018 and restarted it. I didn't have to reboot the machine.
I don't recall if SP2 or SP3 was downloaded, sorry! The version running is 21.3.0.141 if that helps.
That's the latest version number, and the 3 indicates that SP3 was installed.
