Under some circumstances I could not remove files/icons in my custom media Library/Folder
For example: I did a Time Remapping sequenze -> the sequenze is automaticly insert in my Library.
After I remove the "TimeRemapping01.vsp" file/icon from my custom Library and switch to another folder the files/icon is insert again.
Can anyone reproduce this error?
Can't remove file/icon in custom media Library
Re: Can't remove file/icon in custom media Library
Sorry no I cannot replicate that issue, when I delete the vsp from the library it remains deleted.
If you press Shift + delete to remove the vsp from the library, you will also be prompted to remove the actual file which is saved to the hard drive here:-
C:\Users\UserName\Documents\Corel VideoStudio Pro\21.0\TimeRemapping
Are you sure the TimeRemapping01.vsp is the correct one and not TimeRemapping02.vsp or TimeRemapping03.vsp etc
I did have some problem in using Time Remapping and setting Freeze Frame, would not work, then I was able to apply, try again and cannot apply, hmmm
Dirk184
- motherboard: Intel
- processor: i7-7700HQ
- Video Card: NVIDIA 1050
- Hard_Drive_Capacity: 512 GB SSD
- Corel programs: VS 2018, PSP 2021<-> x3, MotionS
After Library Manager > Reset Library - everything works as designed.
