3D default title not showing in editor window
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
VS 2018 3D titler
Click T, select 3D titles, drag preset to title line, double click it.Default text does not sow in editor window.What am I doing wrong
Re: 3D default title not showing in editor window
Hi Kenneth
I dont think you are doing anything wrong but Make sure the timeline clip is selected.
Immediately above the timelines are the tool icons, if you select the T3D does that open the 3D Title Editor
It will also show on the task bar as 3D, typically a blue icon.
Have you tried resetting the program by re-naming the 21.0 folder, ask how if you are unsure.
Ken Veal
ram: 32 GB
Post by Ken Veal »
After clicking the T3D button the timeline clip in title 1 line says 3D tiltle and has a yellow surround on a green background .The VS preview window says 3D text in a white 2D form.There is a message to say that the 3D Editor is running, please close to continue editing-I guess this means if I want to edit in VS.
Regular presets are showing in the left panel.I cant access 3D titles from the drop down arrow.Clicking the blue task bar icon opens the editor.The text settings box shows 3D text but there is only the x+y lines in the editor window.Should it be required to reset I do not know how to.
Closed editor, dragged preset to Title 1,”3D Text" shows in VS preview window, double clicked the title line clip and get the same result and message as before
Kenneth
Do you see the 3D icon on your tool bar, as image
Ken Veal
ram: 32 GB
Post by Ken Veal »
The blue 3D icon on the task bar shows as soon as I clickT3D.I did mention clicking on it in my last post
Hi Kenneth
The message to close the editor, as my image in earlier post is ok.
Once we open the 3D editor the main program is disabled
To use video studio again we must close 3DT editor
Are you having any problems when using 3DTE
I'm slightly confused here. You (Ken) seem to be using both the preset titles which have come with VS for many years, plus the new 3D Title Editor. If my assumption is correct, then don't use the presets or you will end up with two titles in the same space.
Instead, with your video in the main timeline and nothing in the Title track, simply click the blue T3D button. When I do that I get the white "3d Title" against a green background clip in the Title 1 track and white "3D Title" on the preview screen. The 3D Title Editor does not -- at least in my case -- open for a few seconds, but eventually does. If it does not, then look at your computer task bar to see if it is there (blue button with 3D on it). You simply left click it to get it superimposed over VS.
The message saying that the 3D Editor is running, please close to continue editing, remains there while I am editing the title in the 3D Title Editor. And when you close the 3D Title Editor and go back to VS, the message disappears.
But with the 3D Title Editor window open, I see in its preview screen the video in my main timeline plus the big white 3D Title over it. Up in the top right corner are the Settings, the first being Text Settings. Under that is a dark grey window with, in lighter grey, the words "3D Text". I highlight that and delete it by inserting my own words. Then I use the other Settings to customize how my title will look back in VS. When satisfied, I close the 3D Title Editor and am back in VS with the new, edited title appearing on screen.
Ken Veal
ram: 32 GB
Post by Ken Veal »
1 With nothing in the Title track and colour in video track
2 Blue T3d button not available in task bar
3 Click T3d button above timeline
4 3D title editor window opens.Blue 3D button is now available in task bar
5 “Title” shows to the left of drop down arrow in VS and regular VS presets present in VS
6 The words 3D text show in white in the VS preview screen and 3D title shows in Title 1 track on a clip with a green background and yellow surround
7 “3D Tex”t shows in the text settings box, changing the text still does not make any thing appear in the 3D title editor window
OK. Well, while in 3D Title Editor, go over to the top left hand corner where you should see "Presets". The first listed is Objects. Left click that and Test Objects should appear, accompanied to its right by a set of boxes containing coloured and bevelled text all saying "3D Text". Click on one of them. It should appear in the preview screen as well as in the Text Settings box in the top right. If it does, then you can proceed to edit it. Does that work for you?
Kenneth
do you see this panel, there have been some issues where the panel does not show?
If you do not see this click the 3D icon on tool bar.
click image for larger view
Ken Veal
ram: 32 GB
Post by Ken Veal »
1 With nothing in the Title track and colour in video track 2 Blue T3d button not available in task bar
4 3D title editor window opens. Blue 3D button is now available in task bar
5 3D Tex”t shows in the text settings box
6 Nothing shows in the 3D title editor window
8 Clicked on blue 3D icon in task bar, this takes me to VS
9 The words 3D text show in white in the VS preview screen and 3D title shows in Title 1 track on a clip with a green background and yellow surround
10 The message to close the editor hides the T3d button above timeline
11 (Item 10 was Trevor’s advice>to click button above timeline)
12 In 3D Title Editor, go to top left hand corner "Presets". The first listed is Objects. Left click that > Test Objects >Clicked Test Objects>
13 A column of boxes containing coloured and bevelled text all saying "3D Text" show
14 Clicked top one, it is surrounded by orange box
15 3D text is showing in text setting box
16 Nothing shows in editor preview screen
Withdraw beaten again
Hi Kenneth
Now you know better than that as to give up, beaten again, never.
Ok first a typo, the text in 12 should read “Clicked Text Objects>
Not Test Objects
Not a problem though
I think a re-install of the program is on the cards
Close Video Studio
First I would try re-installing the 3DTE
Go to Program and Features and uninstall Video Studio 3D Title Editor
3DTE will disappear from Video Studio.
with Video Studio closed
Then install the plugin again from your download files
\64bit\Ultimate\Setup\RunTime\
Double click the file
VideoStudio_3D_Title_Editor.exe
There should be no problems in installing that file.
Run Video Studio and the 3DT should be available from the timelines tool bar
Does it work, is there any improvement.?
If no I would like you to uninstall the full program using the VS2018_Cleanup tool, download from here
viewtopic.php?f=1&t=59847
That should also uninstall 3DTE
Now install the program again from the Web Installer, deselect all options other than the Main program, that includes service pack 2.
Installing the main program should also install 3DT.
Ken Veal
ram: 32 GB
Post by Ken Veal »
To re-install 3DTE
1 Close Video Studio
2 Control Panel>All Control Panel Items>Programmes and Features
3 uninstall 3DTE
4 install the plugin again from your download files
5 Could not find \64bit\Ultimate\Setup\RunTime\ in download-programmes
6 A windows search brings up 2 icons, one is VideoStudio_3D_Title_Editor.exe
7 the other icon is called run time
8 I double click the run time icon –VideoStudio_3D_Title_Editor.exe shows with an exclamation mark on a solid yellow triangle inside a blue square shows above this text after trying to copy and paste to here.
9 I doubled clicked the .exe file and installation takes place
If it is of any use I have a back up disc purchased with VS Ult 2018.
Hi Kenneth
Follow that up with a reset of the program by renaming the 21.0 folder to 21.0_old
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\21.0
And if that does not work all I can suggest is a clean install using the Cleanup tool to uninstall the program.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Went to C:\Users\Ken\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro(x64)21.0 Changed name of 21.0 folder to 21.0_old
3 Clicked T3d button above timeline
5 3D Text shows in the text settings box
6 Default text shows in the 3D title editor window Yes!!!!
Tried to open VS--get notice to wait ,open 4.VFX.Left this running for about 15 mins, closed
VS via task manager then re opened VS with no problem .
Clicked T3d button above timeline, got the editor window with the default text in the 3D title editor window .Tried some editing and everything seemed to work ok .
Thank you so much Trevor and Ken B for all your time and help, another battle won
