Long clips and the effects don't move at all.
jezzer
motherboard: MSI Z170A PC Mate
processor: Intel Core i5-6600 3.30GHz
ram: 8GBx2
Video Card: Asus GeForce GTX 960 2GB
sound_card: Onboard Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: BenQ "24"
Corel programs: Videostudio X8.5
Post by jezzer »
My daughter was messing around with some videos she wanted to add some of the moving effects likes bubbles, if her clip is very short as in seconds then they move, but if she has a 5 minute clip then they just stay static why is this? Is it a flaw in this version?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Long clips and the effects don't move at all.
Post by asik1 »
They are keyframes based, so if she took the defaults than them bubbles will moooovvvvveeee verry sssllloooowww in a 5 min clip. but if you scroll jump you will see they moved.
Panasonic X900m, VXF1
jezzer
ram: 8GBx2
Post by jezzer »
Didn't know that myself as i have never used them, might be a bit hard for her to do then, is there a tutorial on how to do it?
Hi jexxer
Can you make sure Smart Proxy files have been created for the video file, that could / may improve playback.
jezzer
ram: 8GBx2
Post by jezzer »
Hi Lata i don't think that will help in this case, when she made what she did and rendered it still came out not moving.
In which case I would suspect the type of video, Is it the same as the shorter clip?
Can you provide the properties of that video.?
Right click the clip on the timeline and choose properties.
If the video was recorded with a I phone then would use a variable frame rate and those can cause problems for editing programs, your best option is to convert the video to a more editable format using a constant frame rate.
Oh If you remove all effects are you able to render the clip.?
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Trevor, the problem is not the video, it's the bubbles.
put them on a 5min clip and you'll see they hardly bubble...
Hi Thanks asik
Now I see the problem
The bubbles move over the screen and longer clips cause the effect to slow down.
I did try cutting the clip into smaller sections that seemed to work but one minute seems still to slow
There is a speed setting from Customise Advanced again does not speed up enough.
jezzer
ram: 8GBx2
Post by jezzer »
Yes you now see the problem lata, I am thinking about upgrading to VideoStudio 2018 so i thought i could give this version to my daughter, I have never used the bubbles effect so when my daughter said it wasn't working i had a go myself tweaking everything including the speed setting in the advanced tab which didn't seem to improve it much.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
These FX's not meant for long clips. VS2018 will be just the same on that aspect.
jezzer
ram: 8GBx2
Post by jezzer »
Thank you asik1. :)
I was meaning to say i want to upgrade not to do with the FX's, So then i can give my daughter this version that's why i have been letting her play around with it. But i have i feeling if they are not made for long clips then it might not be for her.
Hi Jezzer
Are the bubbles effects that important, I ran X8 to check the offers and it was giving me a 75% discount that’s just over £21 for the 2018 ultimate version.
If you do not see a popup discount offer go to Settings Messages, the discounts should show there.
I must admit I had not realised that the effect slows with longer clips, like Asik I would add to small clips, maybe when creating an intro.
jezzer
ram: 8GBx2
Post by jezzer »
I completely forgot about the upgrade as i had turned off the messages a long time ago, Thanks :D £21 for me as well.
Just a thought about upgrading this way if i do will this mean my daughter wont be able to have this version on her PC?
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Jezzer,
back to the bubbles,
the only way to make a faster bubbly shot is by chopping/duplicating it this way
Hi Jezzar
The purchased version is the full Ultimate version with its own serial number and not an upgrade from the older version.
You would have two separate programs, we are of course only allowed to install the same version of Video Studio on one computer as EULA, however I do not know how Corel polices that although the web installer aka stub is more complex, we have to provide a serial number to download then install. Effectively we register before installing.
With previous versions, serial numbers were entered after download whilst installing.
For re- installs we are prompted to register, simply adding the original email address is sufficient.
