Rendering CPU usage
jezzer
motherboard: MSI Z170A PC Mate
processor: Intel Core i5-6600 3.30GHz
ram: 8GBx2
Video Card: Asus GeForce GTX 960 2GB
sound_card: Onboard Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: BenQ "24"
Corel programs: Videostudio X8.5
Rendering CPU usage
Post by jezzer »
I tend to record things in AVCHD and i also render to that. If i use certain FX filters like bubbles then my CPU ranges from 50-60% but other filters my CPU ranges from 90-100% is this normal? i thought my CPU should be used fully no matter what filters i am using. I have recorded in MP4 and render to that, I also get the same results.
I have turned off all hardware acceleration and had it on but its still the same.
If I Add:
Motion blur: CPU is 40%
Bubbles CPU: 62%
Kaleidoscope: CPU 100%
Charlie Wilkes
motherboard: Hewlett-Packard 18FA 82.27
processor: i5-3317U
ram: 6gb
Video Card: hd 4000
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 250 gb SSD
Monitor/Display Make & Model: Generic PnP Monitor (13.9"vis, December 2013)
Corel programs: VideoStudio Pro X9
Re: Rendering CPU usage
Post by Charlie Wilkes »
I would guess the motion blur and bubble filters are single-thread processes so one core is doing most of the work. You could test this hypothesis with a utility like HWINFO64.
https://www.hwinfo.com/download.php
jezzer
ram: 8GBx2
Post by jezzer »
Thanks i will use that software when i have the time.
SoNic67
motherboard: Dell Precision T7610
processor: dual Intel Xeon E5-2667 V2
ram: 64 GB
Video Card: nVidia GTX 1080
sound_card: SB ZxR
Hard_Drive_Capacity: 8 TB
Monitor/Display Make & Model: AOC U2879VF
Corel programs: VideoStudio 2020
Post by SoNic67 »
Windows Task manager shows the exact CPU utilization and cores used.
jezzer
ram: 8GBx2
Post by jezzer »
SoNic67 wrote:Windows Task manager shows the exact CPU utilization and cores used.
Please explain on how to know in windows task manager? Thanks
jezzer
ram: 8GBx2
Post by jezzer »
Do you mean you can see by the graphs? if so this screenshot suggests it is using all 4 cores.
wpaul98
motherboard: Dell XPS8300 0Y2MRG A00
processor: 3.40 GHz Intel Core i7-2600
Video Card: AMD Radeon HD 5770
sound_card: Integrated
Hard_Drive_Capacity: 2.6TB
Monitor/Display Make & Model: DELL U2713HM, DELL S2409W
Post by wpaul98 »
In the Task Manager, Performance tab, lower left corner you will find a button that reads "Open Resource Monitor" This will open the Resource Monitor window. In the CPU tab on the right, you will see the load of all the CPUs on your system.
Hope this helps.
jezzer
ram: 8GBx2
Post by jezzer »
As you can see they are all being used the first picture is without anything and the second picture is with motion blur added. The second one is showing its not being used much but they are all used.
https://i.imgur.com/i0S8As7.jpg
https://i.imgur.com/q997PY8.jpg
jezzer
ram: 8GBx2
Post by jezzer »
If anyone could do a little test by adding motion blur and see what your CPU is using i would be grateful, because this is bugging the hell out of me i don't think its my system.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
during project loop playback
Panasonic X900m, VXF1
jezzer
ram: 8GBx2
Post by jezzer »
Hi Jezzar
The first image shows rendering without Motion Blur, I did deselect Smart Render to allow the program to do at least something
As you see it is using the CPU pretty well at 85 %, then the program has little to do in the way of encoding.
If I had added a transition we would see the rate change as the workload increases when rendering the transition.
The second image is with Motion Blur, now the program has some work to do, and like me I slow down when working hard. So the program only uses 41% cpu, if I were to add more filters that would reduce as the workload increases, taking the encoder / program longer to rip things apart then reconstruct them. Rendering takes longer.
The question asked is Video Studio capable of doing this quicker?
Use Smart Render and the easy sections gets done quickly, reducing render times.
Everyone seems to complain about rendering and CPU usage but nobody has produced a project as a benchmark, I can render in real time, and 2 times for complex projects.
Rendering to different settings as original video is also harder to do, where as like for like works well especially using Smart Render.
My first pc, a long time ago now, took ages, 12times, a 40 minute project taking 8 hours, thankfully those days are over
jezzer
ram: 8GBx2
Post by jezzer »
Thanks lata
That now confirms that it isn't my PC, your CPU usage is just like i'm getting.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
I didn't get any "amazing" improvement when I switch last year from i5-2400 4GB ram 7-32b HDD system to my current i5-6600, 8GB 7-64b SSD system. My regular (lectures) projects took ~1X-1.5X duration, and about the same now.
