The frame size... does not match
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Post by qtrim »
Hi. It looks like this was last asked in 2011. I have a video file (details below) that I drop on the timeline and want to smartrender. When VS10 prompts to change the project setting to match I say yes. But when I go to smartrender I get this notice:
"The frame size (480 x 270) of the video file does not match the settings and therefore cannot be trimmed." I can render it to another size, but that re-encodes it.
Any ideas for a fix?
NTSC non-drop frame (30 fps)
MPEG-4 Files
24 bits, 480 x 270, 30 fps
Frame-based
H.264 High Profile Video: 340 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 163 Kbps
Using VideoStudio since old Version 7. Currently using X10.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: The frame size... does not match
Post by asik1 »
"I drop on the timeline and want to smartrender."
What do you mean? it's a single clip you need to trim few parts off and render it shorter?
Panasonic X900m, VXF1
qtrim
ram: 4GB
Post by qtrim »
Yes, it’s about 20 mins long, I cut a few spots out, fade in and out the ends, then go to render and get that message.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Well, you can't render it as mp4 as VS can handle only discrete MP4 resolutions and yours isn't one of them.
So your next best friend is XVID as AVI where you can set that size.
**if you do any trim and fades VS will re-encode anyway.
