Filter Attacks
lioness035
processor: Intel Core i3-4005U CPU
ram: 4GB
Hard_Drive_Capacity: 686GB
Monitor/Display Make & Model: Toshiba Notebook Laptop
Corel programs: Corel Paint Shop Pro X7
Filter Attacks
Post by lioness035 »
Hi I am new here and not sure who to ask or what to do. I have a Toshiba laptop that runs Windows 7 64 bit Pro on it. I use Corel PSP X7 and cant get the filter attack plugin to work on windows 7 or 10. Any help greatly appreciated.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Filter Attacks
Post by JoeB »
I don't know the Filter Attacks plugin. Where is it available? And when was the last time the plugin worked - i.e., on what computer and particular operating system?
That said, there could be a couple of reasons that it doesn't work. You do not say whether or not you are using the 32bit or 64bit version of PSP. And I suspect that, at the very least, Filter Attacks is no more than a 32bit plugins so if you are using 64bit PSP it won't work.
Also, if it is an older plugin - which I suspect it is - then it's possible that some dll's are missing from your System folder that are required to run some old plugins.
EDIT: I found the Filter Attacks plugin. It was apparently created in 1997. Windows reports that it cannot be run on my computer. I suspect that it is not even 32bit compatible but perhaps just an old 16bit plugin. So I can't imagine that it will work for you and dll's likely have nothing to do with it because I have ALL plugin dll's - needed or not - and can't even install Filter Attacks. I do have a 64bit operating system like you have, and maybe it will install on a computer with a 32bit system, but I wouldn't know.
JoeB
Using PSP 2019 64bit
