Gradfilter Pro settings not in xml file
mikmak
Post by mikmak »
I use Gradfilterpro a lot in my workflow; but the settings for gfp is not saved in the xml file, so I have to start all over with the gfp settings every time and that annoyes me... In the 'aftershotpro.xml file is the following line:
6906.630: Warning: slow tiles used because plugin is not white listed: "GradFilterPro"
The plugin entry in the same file::
Identifier: com.corel.GradFilter
Version: 3.0.0
Path: <User Home>/Plugins (64-bit)/GradFilter.afplugin
Any ideas what to do ??
Regards/Per
mikmak
Re: Gradfilter Pro settings not in xml file
Post by mikmak »
Problem solved... Gradfilter pro settings is not stored in the xml file. It is in the cache folder. My folder was corrupt. I moved it and now it works again.
/Per
