Remove Haze
okyou
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 2TB
Corel programs: X9 Ultimate
Remove Haze
Post by okyou »
Hello,
Is there any way to remove the haze in this picture ? Thanks
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: Remove Haze
Post by flagpole »
Maybe:
I selected the about the top third then feathered it outside a bit till it hit the bottom. (because there appears to be more haze at the top.) In the selection i reduced the brightness and increased the contrast. Roughly (-20 and +27) I would have sharpened it if i'd had the original image too.
It's just a rough idea, but haze in general blurs, lightens and flattens. so you need to do the opposite of that. Maybe increase the saturation a tad too.
flagpole
Re: Remove Haze
Post by flagpole »
Thanks for your help.
No it's really no problem.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Remove Haze
Post by JoeB »
Just for fun (because of a conversation in another thread) I thought I'd try it with the Athentech Perfectly Clear Dehaze filter. Then I applied a script called Rusty's New Dynamic Range Script. The script was to try to lighten some of the deeper shadow near the bottom of the image - i.e., to even out the dynamic range somewhat. It would have been nice to have a much larger image to work with - not a lot of pixels here. :-)
pic_Perfectly Clear Dehaze Filter_2.png (127.91 KiB) Viewed 6147 times
JoeB
Using PSP 2019 64bit
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: Remove Haze
Post by ehume »
I compared the dehaze filter in Perfectly clear (thank you for the find) and the dehaze filter in Affinity. Here is the latter:
Clearly, there are algorithms floating around out there.
JoeB
ram: 8 GB
Re: Remove Haze
Post by JoeB »
ehume wrote:I compared the dehaze filter in Perfectly clear (thank you for the find) and the dehaze filter in Affinity. Clearly, there are algorithms floating around out there.
Yep, and I think that's the point. :-) "Haze" covers a lot of situations (fog, glare, dirty camera lens) and affects different scenes in different ways from a digital perspective. So I don't think there can be a "one size fits all" solution. As @flagpole pointed out in his post, there are several aspects that are affected by "haze", so different subjects might require different adjustments - subsequent to the original "dehaze" algorithm - to color, contrast, light diffusion, etc. - to obtain the best result for a specific digital image subject.
So far - for me - Perfectly Clear's single Dehaze filter with Strength slider provides the best simple solution for many subjects. And its other options within the same plugin provide at least more ways to tweak the result. But even then, some images can still benefit from further tweaks in PSP with tools like Clarity and/or Levels and/or Sharpening.
And, of course, the decision as to satisfaction with the final result is in the eye of the beholder, being the PSP user doing the optimization. :-)
JoeB
