PSP 2018 Freezing and tools not working
Leslie
processor: intel core i7
ram: 32 gb
Video Card: intel iris
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
Corel programs: 2019 Ultimate, 2022 Ultimate
Post by Leslie »
Hi, All
PSP is freezing quite frequently. I go to open any tool, and it freezes. Doesn't matter which one.
It happens whether or not I am using a keyboard shortcut.
I just re-installed X9, but am hoping to find a solution to 2018.
Hope someone has a solution.
Thanks so much,
Leslie
Kathy_9
Hard_Drive_Capacity: 2TB
Re: PSP 2018 Freezing and tools not working
Post by Kathy_9 »
Leslie, have you tried doing a reset by holding the Shift key? Here are the instructions for X6 but they work for all versions.
https://support.corel.com/hc/en-us/arti ... figuration
Leslie
ram: 32 gb
Post by Leslie »
No, haven't done that. Was hoping there was something I could try without losing my settings.
Does it matter which method I use?
Kathy_9
Post by Kathy_9 »
Option 1 gives you a little more control over what is reset as you can check or un-check areas. Make sure you save your workspace if you've customized it.
click for larger view
Leslie
ram: 32 gb
Post by Leslie »
So just reset general preferences and delete cache files and leave the others alone?
Kathy_9
Post by Kathy_9 »
You can start there as part of your troubleshooting. I would also check dialog positions and last used settings.
Leslie
ram: 32 gb
Post by Leslie »
I have reset my psp, and have figured out that when I create a new blank image psp will freeze. Not all the time, but enough that it is very annoying. I have to save my work every 30 seconds so I don't lose it.
Anyone have a fix other than resetting, which I have already done?
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I don't know if this will help us troubleshoot, but could you provide the settings you use when creating a new blank image?
JoeB
Using PSP 2019 64bit
Leslie
ram: 32 gb
Post by Leslie »
It doesn't matter if I click on the icon or hit ctrl+N. PSP will freeze.
I can't create a new blank image.
disgruntled
Corel programs: PSP 2018 ultimate
Post by disgruntled »
Corel "support" also told me to reset. That was no help.
For me, the freezing only happens when I am offline, so I presume it is related to spyware installed with PSP.
Deleting Protexis didn't solve the problem, though. Maybe there is more spyware that I don't know about, or maybe just more instances of it.
JoeB
ram: 8 GB
Post by JoeB »
disgruntled wrote:Corel "support" also told me to reset. That was no help.
Protexis is the licensing service used by Corel. When you open PSP Protexis validates that your copy of PSP is a legitimate copy. If you are offline or delete it then it can't validate your version and you won't be able to use all of the PSP features. I always use my firewall (ZoneAlarm) to block all programs - except those that are internet ones - from accessing the internet, including PSP. But I don't block Protexis (PsiService) or PSP won't work properly.
I'm not sure how validation is done by those who own PSP and actually don't have Internet access for Protexis to work, but maybe someone else knows the answer to that.
JoeB
Leslie
ram: 32 gb
Post by Leslie »
I'm never offline, so that's not the problem for me.
And I have legit copies for all my psp's.
I'm using File~new instead of the shortcuts, so I'll see if that keeps working.
disgruntled
JoeB may be on to something. Even if you are online, your firewall may be blocking Protexis from calling home.
If Protexis is your problem, what looks like a good solution (better than what I did) is posted at (https://www.mydigitallife.net/how-to-di ... rvice-exe/).
Leslie
ram: 32 gb
Post by Leslie »
Geez,I'm scared to death to try that.
btw, file~new finally froze the program as well.
Why would psp just start messing up out of nowhere? And why would an older copy do the same thing? (I re~installed one to see if it worked).
Just rhetorical questions, I guess.
I just keep saving my work every 2 minutes and hope for the best.
notyou87
ram: 8gb
Corel programs: Paintshop Pro 2018
Post by notyou87 »
Leslie wrote:Geez,I'm scared to death to try that.
I have the same issue with ctrl+n and opening from the menu.
It does the same with Templates also, if I try open them it freezes PSP completely.
My workaround is to always open a file, copy and paste it into a new image, and then resize canvas to whatever I need it and delete the image. It's annoying but it only takes 20 secs to do and stops you from having to pull out your hair and want to throw your pc/laptop. Sometimes I forget though, that it freezes so will try make a new blank file and then as soon as I do I realize and scream!
