keeping picture information on export
How do you keep the picture information such as the type of camera, lens, aperature, etc when you export a jpg?
Thank you
Thank you
TimW
- motherboard: ASUS M5A99FX
- processor: AMD FX8350 8 core 4.0GHZ
- Video Card: AMD Radeon HD 6900 Series
- sound_card: On Board
- Hard_Drive_Capacity: 256GB SSD
- Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
- Corel programs: PSP X8, Knockout 2
Re: keeping picture information on export
If when you say "Export", you mean Save, then under Save or Save As, click on Options, then make sure the "Save EXIF information" box is checked. That should do it.
theavy
- motherboard: Dell 0CNDTP A00
- processor: Intel Core i7-9750H
- Video Card: NVIDIA GeForce RTX 2060 6GB
- sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
- Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
I don't know that you can export the exif info in Paint Shop Pro when converting your image to jpg. Aftershot Pro has that capability though.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
See TimW's post just before yours.theavy wrote:I don't know that you can export the exif info in Paint Shop Pro when converting your image to jpg. Aftershot Pro has that capability though.
JoeB
Using PSP 2019 64bit
JoeB
theavy
Thanks... I saw it. But the original question asked about 'exporting a jpg', which is why I responded the way I did.See TimW's post just before yours.
- hartpaul
- ram: 8 Gb
Again one only has to look and check it out on your system.
You can Export a jpg using File > Export > JPEG Optimiser and there is a tick box there under the Quality tab for saving the EXIF data but only in Standard mode, not in Progressive mode.
theavy
Sorry... I totally missed that! My humble apologies!
JoeB
- ram: 8 GB
There is still something that can be - and to me is - quite confusing about the jpg save dialogues. When you click on Options you get 3 "encoding options" - Standard, Progressive and Lossless. In my case the Save Exif box on that dialogue has the ability to check or uncheck it in Standard. If I choose either progressive OR lossless the checkmark is still there but the box is greyed out and can't be changed.hartpaul wrote:Again one only has to look and check it out on your system.
Then, if I click the Optimizer button, that dialogue 2 "format" options - Standard and Progressive. And if I have Lossless selected in the previous dialogue then I can't select Progressive in the Optimizer dialogue.
So what's with the Lossless option in the Options dialogue under Encoding? And what is the difference between Standard and Progressive encoding as opposed to Standard and Progressive format?
JoeB
JoeB
Not sure I'm fully understanding "standard" and "progressive". I've tried searching the PSP 2018 Help and Manual for exporting and still confused.
I am trying to make HDR panorama's partially with PSP 2018 and finishing in PTGui. When I opened the finished JPG photos in PTGui after HDR processing in PSP, I got a message that said that "EXIF data not present" and something about the EXIF data was apparently not transferred or not captured by your camera. I am shooting with Canon 6D, and a 12mm Samyang Fisheye 180 FOV. I understand that the lens won't transfer data as it is a fixed fisheye, but don't understand camera data not being transferred. Corel Exposure Merge process is to create and HDR file then in final processing (Step 3) to save into a JPG file. I don't see ANY options in that process to save or include EXIF data, but that is important when the file gets to PTGui. (I am making a 360 x 180 Equirectangular Pano in PTGui.)
So ... is there a way to get that EXIF data to the finished file by Corel, or am I just out of luck? What am I missing, and where did I miss it? Is the solution in the documentation?
In any event, thank you for taking the time to read this, and I will appreciate any guidance / suggestions on this.
bruce1951
- ram: 8gb
Keep in mind that HDR will involve multiple files. Each with its own exit information. When the files are combined into one file then which exit data should be used? Most/all HDR software will not know what exit data to use from which file. So it with ignore the exit data altogether. In some cases basic, unchanged exit information may be used, but not all of it. ie what shutter speed would be used if all exposures were different?
Bruce
Bruce
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
ExifTool is a commandline tool that includes several options including copying tags from one file to another
https://sno.phy.queensu.ca/~phil/exiftool/install.html
I don't now if it works directly with RAW images if that's what you're using. But here is the basic command for moving EXIF data.
Code: Select all
- flagpole
- motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
- processor: Ryzen 2600
- Video Card: RTX 2060
- sound_card: on board
- Hard_Drive_Capacity: 6.5TB
- Monitor/Display Make & Model: Iiyama 27"
I believe there's a GUI for that.LeviFiction wrote:ExifTool is a commandline tool that includes several options including copying tags from one file to another
Code: Select all
Further I believe it's called exiftoolgui
