PSP 2018 x64 freezes on exit every time
vsguru
Corel programs: Paintshop Pro 2018, X9, Painter Essentia
Post by vsguru »
I have been using (and like) PSP2018 x32 and it works fine. I started to use the x64 version and it also works fine. I can use all features, save files, etc. however it freezes on exit every single time. I have to use Task Manager to end the program. x32 does not do this. I have an HP 610f TouchSmart All-in-One running Windows 10 with 8GB RAM (the max supported on this older but otherwise great beast). I have not had this issue with any other 32 or 64 bit application. The one thing that might be in play is I am a Windows Insider getting frequent updates on the latest version. Having said that and as I said before no other apps seem to have trouble with it. I don't think that's the issue because I kept PSP X9 x64 and it runs and exits just fine. Any ideas?
Thanks!
vsguru
vsguru
Re: PSP 2018 x64 freezes on exit every time
Post by vsguru »
BTW, I completely uninstalled PSP 2018 and reinstalled it and issue is no longer occurring BUT the UI has changed from the initial install even though I used the same install files. I now only have the Edit tab. See the attachment.
I had several 3rd party packages installed on the original installation (as part of the Ultimate package) and have not yet re-installed those so is it possible one of the Ultimate packages was causing the freeze during exit?
-vsguru
I don't know why the same installation files gave you a different UI. But the UI in the photo you attached is the Essentials workspace. If you want the Complete workspace, right click virtually anywhere on the screen. A menu will appear and at the bottom is "Workspace". If you click on that you will be able to toggle between Essential and Complete.
vsguru
Post by vsguru »
Thanks very much Ken, your suggestion worked!. I had never used the essentials workspace before so I did not recognize it.
-vsguru
