Text-only custom toolbar reloads with image+text
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
In PSP 2018 x64 I've created a custom toolbar Books Scan with some commands and some bound scripts. When I select Customize (right-click empty edit area), I can set the various items to show only text. The next time I open PSP it's back to image + text.
I tried saving the workspace, closing PSP, opening and loading that workspace, but it still does it.
(For me, reinstalling or resetting PSP to defaults isn't worth the time--I have several versions installed and point all of them to a single set of folders, i.e., all versions point to one Brushes folder, etc. I would have to reset all that manually for PSP 2018.)
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Text-only custom toolbar reloads with image+text
Post by LeviFiction »
I can't help with this problem in particular. But I saw the little aside you put there at the bottom and wanted to respond to that.
So if I gave you a script that could backup and restore your file locations it would be worth it to you to try? Cassel showed me an old script that copied over PSP8 file locations into PSP9. It can be adapted pretty easily to a backup and restore script.
Technically don't need a script. You can just do a quick export of your registry and load that back in after closing PSP. Open Regedit.exe go to Computer\HKEY_CURRENT_USER\Software\Corel\PaintShop Pro\X10\FileLocations Right-click on FileLocations and choose Export. Give it a filename. Now, Reset PSP, close PSP again, double click on the reg file you just created and it'll reload your file locations the next time PSP runs.
But if you'd prefer a script to using the registry that is doable.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
LeviFiction wrote:I can't help with this problem in particular. But I saw the little aside you put there at the bottom and wanted to respond to that.
I suspect that a lot of people would be happy to have that script! :-)
JoeB
Using PSP 2019 64bit
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
JoeB wrote: I suspect that a lot of people would be happy to have that script! :-)
I agree as there are those who shy away from anything registry related.
Rick_R
Post by Rick_R »
I'd rather not try. I really don't use PSP much and Book Scan is the only custom toolbar I've made. I currently have 32-bit X8 and X9 installed and 64-bit X9 and 2018. I had 32-bit 2018 installed but it looks like somehow the install got partially deleted and I haven't reinstalled it. Also, I've downloaded the 2018 64-but Update 1 but haven't installed it.
One of the things I do is set up junctions that point to a different drive, to not clutter up my SSD C:\ drive. Whenever I do an install, the installer puts all the files and folders in the original C:\.. location, then I have to move everything, then update all the file locations.
Normally, I just use the Tools toolbar, which works fine.
