VideoStudio has put triple scoop music in my public folder
jezzer
motherboard: MSI Z170A PC Mate
processor: Intel Core i5-6600 3.30GHz
ram: 8GBx2
Video Card: Asus GeForce GTX 960 2GB
sound_card: Onboard Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: BenQ "24"
Corel programs: Videostudio X8.5
Post by jezzer »
I have been sorting all my files and folders on my pc (Windows 10) and in my public Music folder all of the triple scoop music is in there, Why would that be i don't want it to be in there how can i move this to the proper windows install folder? :|
Re: VideoStudio has put triple scoop music in my public fold
Well yes the program is a bit untidy when it comes to saved file locations.
You could simply move the folder to another location
Create a new library page for those clips and import as normal.
When opening the old TSM library a new empty folder (hopefully) will be created in Public.
If you do not use these then right click the TSM library name and Hide folder.
And of course re-installing or updating the program will populate these again.
There are other folder locations used to store audio clips rendered when adding to the timelines. Those you cannot change
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\21.0\Triple Scoop Music
And I think for Auto Music
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\21.0\ScoreFitter
Post Updated, i forgot
C:\Users\Trevor\Documents\Corel VideoStudio Pro
jezzer
ram: 8GBx2
Post by jezzer »
Thanks, What videostudio has done is to install it on the e drive not the main c drive, What i have done is to copy that folder from the e drive to the c drive of videostudio, but i'm now stuck i know i have to go into Regedit and find the location on the edrive and change its path,but i am not sure where i would find it when i go into Regedit? I just want to move the triple scoop music to my c drive so when i open up the triple scoop music in videostudio it opens it from the c drive.
It does not make sense that the program installed a folder to the E Drive unless you have told it to do that?
You said “and in my public Music folder all of the triple scoop music is in there,”
That would indicate that the public Folders are on your E Drive. Is that so.
Did you do that?
jezzer
ram: 8GBx2
Post by jezzer »
Yea come to think about it ages ago i moved the public folder to my e drive, never looked to see what was in them, Only just seen videostudio has put them in the Music folder. So how do i get around this?
I moved it from watching this video: https://youtu.be/-qeZFMYwF1M
Quick Edit: Done now, I deleted the music from the public music folder on my e drive,then opened videostudio and relinked the missing music to where it was on the c drive.
