Some chapter entry frame number exceed the total frames
zagon
Post by zagon »
hi!
I have a hauppauge PVR 150 that came with dvd factory 3 SE...
This program is amazing, althow I can't finalise my first projetcT
I recorded a program (1h30) and it has been stored on 2 mpeg files (dvd qulity)
So, I joint both parts and I had to set the audio compression to LPCM to get a final length < 4.7 Gb..
everything seems to work find, it begins the rendering, and after 15_20 minutes I get the following error:
14252:1:0
I don't know if the problem is linked to the several part I have pasted together, or to the compression I asked for audio....
does anybody have any experience of that case?
thanks!!!
PS: I'll have a try with MPEG audio compression (which set the total size to 3.7 GB and see if it isn't the problem
ploggy
Post by ploggy »
this means you are placing a chapter point on a frame that is non-existing.
if you have a video file that was captured at 23.976 fps, moviefactory misreads it as 29.97 fps. so any chapter points placed on the frames exceeded will throw up the error.
try removing your chapter points and you will be able to burn that project (as long there is no other burn problems).
Who? Me?
zagon
Post by zagon »
ok!!
I didn't understand at all the point of the error but your explanations are clear...
I'll search where I can remove those chapter points (as it is my first try, I don't want to make any chapters.. just burn the movie on the dvd)
thanks!
