When importing those files VS freeze. Task mgr says app not responding, VS consumes some 60-70% cpu and if importing vids by drag'n'drop, the explorer window freezes as well. I have waited some 5-10 mins before killing it.
The files i'm importing are identified in VLC as
H264 - MPEG-4 AVC (part 10)(avc 1)
1920x1090
FPS 50
Decoded format format: planar 4:2:0 YUV
Oddly enough, importing files from my xperia phone of the following format has no issue whatsoever (from this output, only the fps differs):
H264 - MPEG-4 AVC (part 10) (avc 1)
1920x1090
FPS 29.527928
Decoded format: planar 4:2:0 YUV
If using the "browse media files" function of VS and selecting "info" for the file, it shows up as H.264 Main profile video, upper field first but 25fps, not 50 as VLC says.
I have tested this on 4 different setups:
1. Windows 10, i7-4770, 16G, nVidia driver
2. Windows 10 laptop (pretty freshly installed), i7-8550u, onboard intel gfx
3. Windows 7, i5-3570K, 16G, newly installed for this purpose
4. Windows 7, VirtualBox, newly installed for this purpose
The three physical boxes have the exact same issue - however, running in VirtualBox works which would indicate some kind of hardware issue. I have tried to disable all the hardware acceleration settings in the preferences -> performance tab but it makes no difference.
Don't know if this could be a codec issue and I don't know what codecs VS uses (are they provided by Microsoft or by VS?)
Playing the file in e.g. Windows 10 media player works. One idea would be to convert the files somehow. Importing and sharing the files to MP4 / H.264/25fps using VS in VirtualBox produces files that can be imported into VS on the other boxes but that takes ages.
I'm considering other programs but I've always used VS and have been very satisified in the past.
Happy for any advice - thanks!
