Can you add your own music in the auto music tab?
jezzer
motherboard: MSI Z170A PC Mate
processor: Intel Core i5-6600 3.30GHz
ram: 8GBx2
Video Card: Asus GeForce GTX 960 2GB
sound_card: Onboard Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: BenQ "24"
Corel programs: Videostudio X8.5
Post by jezzer »
I have a video with no sound so i would like to add one of my own music sounds but the song i have is to short for the video clip, Can i add it in the auto music section so it adjusts the length or do i have to make it fit myself?
Re: Can you add your own music in the auto music tab?
No, you have to make it fit yourself. Most likely you will need to loop it or something similar. You can use a third party audio editor like the freeware Audacity.
jezzer
ram: 8GBx2
Post by jezzer »
And i thought it would be easy lol what i had been doing is copying and pasting but that takes to long, I shall have to check out Audacity. Thanks
OBB
motherboard: Dell XPS Studio 8900
processor: 6th Gen i7-6700
ram: 32Gb
Video Card: EVGA GeForce GTX 680 4Gb
sound_card: RME RayDat
Hard_Drive_Capacity: 6Tb
Monitor/Display Make & Model: Multiple
Corel programs: Painter15/Paintshop-pro/Sketch
Post by OBB »
After adding music, if it's too short just copy & paste the auto-music audio track....
If that makes it too long then just either trim the excess off the end or you can simply overlap the copied audio tracks and it will automatically cross-fade between the overlap. But, you usually need to manually tweak the crossfade levels from the audio pane as sometimes the automatic crossfade can be really harsh depending on the type of music... If the music has a beat to it, then you'll need to slide the clip overlap until the beats match up by manually nudging the audio clip forward or backward tick by tick on the timeline until it's seamless...
At least that's what I do when I add my own audio & it needs to be fit for the project...
