Customized frame won't show up
okyou
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 2TB
Corel programs: X9 Ultimate
Post by okyou »
Hello,
I created a customized frame in pgn format and put it in the folder ...VSPContent>Decoration. But when I start up VS again, the customized frame did not show up in Frame library. Do you know what kind of requirement to make my customized frame to show up in the library ?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Customized frame won't show up
Post by asik1 »
did you import it to VS ? placing a file in WIN folder isn't enough.
Panasonic X900m, VXF1
Post by BrianCee »
next to the little drop down where you select which of the graphics libraries you want to use is a small folder icon (add) - click on that and browse to and select your new frame - it should then appear in the library
okyou
Video Card: onboard
sound_card: onboard
Post by okyou »
Thank you very much for sharing. You've save me lot of time looking in the HELP topic and couldn't find this little trick.
