Adjusting Photos from Slides
Aussie Perry
Corel programs: PSP 2018
Post by Aussie Perry »
G'day,
I have thousands of Kodak Slides that I am saving onto my computer & disks. They all have this blue contrast. What program would be best to obtain a more natural photo. I have PSP 2018 also After Shot.
Cheers Perry
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Adjusting Photos from Slides
Post by Kathy_9 »
I'm more familiar with PSP and my suggestion would be to try to correct the color tint by adjusting the white balance. Enhance Photo -> White Balance.
There are other methods but this is quick and easy and can be tweaked to your taste.
Tony Lenton
motherboard: Intel DH55TC
processor: Intel Core i5 3.20 GHz
ram: 12GB
Video Card: GeForce GTX 1060
sound_card: On board Realtek High Def Audio
Hard_Drive_Capacity: 4500 GB
Monitor/Display Make & Model: Lenovo S27i
Corel programs: PSP X6 PSP2020
Post by Tony Lenton »
Hi Perry
1. The software for my (pretty ancient) Epson scanner has a setting for this called Colour Restoration. I presume you are using a scanner with a slide adaptor.
2. I use PSP X6 and the setting I use for this sort of problem is Adjust->Color->Fade Correction.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Same as Tony Lenton :
- Adjust / Color / Fade correction : 100
- and over the previous correction, I made the White balance Warmer (7720) (Kathy's suggestion) :
Slide corr.jpg (177.61 KiB) Viewed 2979 times
But values need to be modified if color cast differs.
LeGrand
motherboard: Asus I 7 2600
processor: Intel 3.4 ghz
Video Card: NVidia GT740
sound_card: include inboard Asus
Hard_Drive_Capacity: 3 T 500SSD
Monitor/Display Make & Model: 2 Asus IPS HDMI
Corel programs: VS2019,X10,PSP2019,CDX7 WINDVD AfterShot
Post by LeGrand »
Jean-Luc wrote:Same as Tony Lenton :
Hy Jean-Luc, sometimes depending of the photos , you cans Try " automatic flash dosing" "Dosage automatique du flash " or the best is Perfectly Clear 3 that I use often . Hope it will help you
Ford GT and Mustang lovers
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
LeGrand wrote:Hy Jean-Luc, sometimes depending of the photos , you cans Try " automatic flash dosing" "Dosage automatique du flash " or the best is Perfectly Clear 3 that I use often . Hope it will help you
I tried it with Perfectly Clear 3 Complete. It didn't do the job nearly as well as a combination of Fade Correction and White Balance-Warmer. And I did it in Perfectly Clear trying several filters and adjustments. So if it could do the job as well as the above combination then it likely would take a lot more effort than the combo described by Jean-Luc, at least from my attempts. And this is coming from a user who actually likes how well Perfectly Clear works swiftly with basic image issues like lack of contrast, tint issues, and faded color issues when most of those are not extreme but just issues that most people regularly encounter with their general candid shots.
JoeB
Using PSP 2019 64bit
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I tried Darkening the image a bit first(Brightness - 20) then Fade Correction (70) and then Red/Green/Blue correction (R+3, G+6, B-20).
Jean-Luc
Post by Jean-Luc »
hartpaul wrote: and then Red/Green/Blue correction (R+3, G+6, B-20).
Your RGB correction is interesting. It acts like in the past with color enlarger and additive filters (I have worked on a "Durst" machine with such filters). Memories... :)
Jean-Luc
Post by Jean-Luc »
LeGrand wrote: ... depending of the photos ...
Yes, if color cast is not extreme, it could do the job... Thank you. :)
LeGrand
Post by LeGrand »
Tony Lenton wrote:Hi Perry
You are absolutely right, I got an Epson V500 photo and the scanner software is absolutely marvelous to correct the photos but you have to learn hos it works, but after you will do miracle with your slide
Tony Lenton
ram: 12GB
Glad you found it OK.
