Difficulty with fade in from black
rkeesecker
motherboard: Dell 0DF42J A00
processor: Intel Core i7-8700 CPU 3-20GHz 3-19 GHz
Video Card: NVIDIA GeForce GTX 1050 Ti
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Insignia 32DR310NA17 [Monitor]
Corel programs: PaintShop Pro 2021
Post by rkeesecker »
Why am I having such difficulty finding out how to start a video with a simple fade in from black? I've not found anything specific about this other than one convoluted way to do it with an old version. The only fade in information I can find in v2018 is for audio. That's fine, but this is a video product. MovieStudio, now owned by Magix, had a very simple and quick way to do it. I'm pleased with Corel VideoStudio, but this issue confounds me.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Difficulty with fade in from black
Post by asik1 »
You can place FADEtoBlack at the beginning of the clip.
Or crossfade with black color from grafics
Panasonic X900m, VXF1
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Post by gewb »
Add a black image, set length as needed. Add opening resource then place Fade to Black or Cross Fade transition between them (click the AB icon, click the droplist arrow then select the desired transition).
Or just add a Cross Fade at the beginning of the first resource.
Or use Custom Motion tool on the first resource and use the Opacity function.
You can find the black colour clip in VS itself. Have a look at the attached image. The red arrow points to what you click on first. Then when the Samples window opens, click on Color as per the green arrow. That also points to the first clip in that library (0,0,0 which is black) though it doesn't show up against the black background. However, it is there and you just drag it to the beginning of your project and adjust its length to whatever you want. I usually then add a crossfade transition between its end and your first video clip in the project to complete the fade from black effect.
